87 ford 351 windser
Old 01-22-2009, 07:15 PM
cosmo10's Avatar
cosmo10
cosmo10 is offline
87 ford 351 windser
ok my ford is still stalls or dies after running good then low rpm slow moving like week spark i check the coil and it read 1.3 ohms i think it should be 0.3 to 1.0 so is 1.3 to high and it kinda sounds like its missing i checkd the ohms on the spark plug wires and the book says 8.9 ohms and i cant even get a reading on my guage the reading jups all around any suggestions i think its arching but i dont see sparks
thanks cosmo10
Old 01-22-2009, 09:34 PM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,703 Likes on 1,377 Posts
What year truck do you have?
Old 01-22-2009, 11:13 PM
bashby's Avatar
bashby
bashby is offline
Checking ohms is a waste of time in my experience, if you can pull the coil wire loose and the coil will throw a spark 1/2" then it is good enough for a mildly tuned engine. I like to then pull each plug wire and see how far it can throw a spark. Its easier to find bad wires and such this way
Old 01-23-2009, 10:24 AM
cosmo10's Avatar
cosmo10
cosmo10 is offline
1987 ford f250
ok its a 1987 ford f250 5.8L
Old 01-23-2009, 10:27 AM
cosmo10's Avatar
cosmo10
cosmo10 is offline
Old 01-23-2009, 11:02 AM
Ritechous_23's Avatar
Ritechous_23
Ritechous_23 is offline
Have your ignition modual checked.I had a 91 tempo and I know its not a truck but it the only vehicle I had that did what is very close to what your describin and the problem with my car was the ignition modual inside my distributor.I hope this info helps.
Old 01-23-2009, 11:06 AM
cosmo10's Avatar
cosmo10
cosmo10 is offline
87 ford f250
my ignition modual is on the out side of the distrbiter same thing though right
cosmo 10
Old 01-23-2009, 02:16 PM
Franklin2's Avatar
Franklin2
You might want to try the other forum, since you have a 87, though there probably isn't much difference in your truck compared to the earlier models in here.
Jager
11-24-2010 03:41 PM
cosmo65
09-13-2009 08:29 AM
cosmo65
09-07-2009 10:56 AM
PersiusOne
1997 - 2003 F150
11-24-2008 07:19 PM
Broncosuds
1999 to 2016 Super Duty
08-20-2007 12:15 AM
Quick Reply: 87 ford 351 windser
