I have a hot-rod project for which I am planning to use a 5.8L engine, C6 tranny and 8.8 3.27 rear end. I already have the engine, tranny, rear end and the intended recipient -- a '56 Dodge 1/2 ton P/U. My questions are: the 5.8 engine is fuel injected (taken from a '89 E-150) which I would like to convert to MAF. Which computer should I use? Another option is to convert it to a carburetor -- any suggestions? The project truck would be used for street use only and, occasionally, towing light loads. My goal is for good reliability, power and economy. I realize the 5.8 is not known for good economy, but I would like to get the best possible.
The biggest benefit of a MAF conversion is the motor's adapability to performance parts. If you're going with a relatively stock build you don't need mass air. Make SURE you need to convert to mass air before you do it, as it's a considerable amount of work to do it.
+1, it not absolutely necessary unless you swap on some heads and install a bigger cam. The long runner EFI intake will deliver more low rpm TQ than a carb could so it's worth keeping for that alone. If you are going down that road a 5.0 mustang ECU is what you want, it's tuned for performance and compatable with a selection of tuners. The Ford kit I have uses a Stang computer and it ran a 5.8 with a cam no problem at all.
Thanks for the replies, guys. Your comments are appreciated and, since I am not planning on any major modifications to my engine, other than cleaning up the ports and adding some suitable headers, there is really nothing major to consider.
Good luck with the swap! Sounds like a good set up.
You might want to concider running a new engine harness (like from painless or something) Instead of having an old retrofitted harness in your pretty rod.
