Another not starting thread! Help!
If anything install your IDM in his truck.
No need for 2 dead trucks!
I also lean towards the IDM in lockout from low RPM or Low HPOP pressure.
Check power to the IPR
Bill
Finally got the truck running tonight! I put new batteries and all new cables on it then tried cranking. Was still not getting anything out of it! So I borrowed a nice snap-on scanner and put on there to check codes. I kept getting a code about the IPR circuit. After not finding a whole lot on here that helped me I just went out to take the IPR apart and see what was going on. Once I had the pigtail unplugged and the solenoid off the shaft I saw my problem! There was a very large amount of corrosion on the pins for the pigtail. Spent some time cleaning it all up and got here to fire right up!
thanks to everyone for the help!!!
