DIY cam phasor update
Old Jan 22, 2009 | 01:21 PM
steeda007's Avatar
steeda007
Hey, has anyone out there taken on the TSB cam phasor repair themselves? I've read the TSB, but didn't want to buy the full repair manual until I knew that it was a doable job... Anyone?
Thanks
2004 Fx4 Super Cab
Old Jan 22, 2009 | 04:54 PM
silverstang's Avatar
silverstang
What are you trying to do? Is your phaser making noise???? What type of warranty do you have left? there are many options (aftermarket wise) that can take care of it. That is if you like modding your vehicle, why not do a little bit while your in there?? They make tons of camshafts for these engines, and there are a few companies that have phaser lock-outs (will stop phaser noise, and also lock out VCT)......Livernois, MMR, and BBR all carry the billet lockouts for the 3v engine. The only downside to doing a cam swap and phaser mods is you need to get a tune for it, but its WELL worth it.
I have never done a pickup truck, but have done many 3v mustangs (same set-up, just a 4.6)........Im curious as to why nobody really does cams in a truck (i think it would be cool).
But If you just want to stay factory and install a new phaser, its not that bad of a job.
Old Jan 23, 2009 | 09:14 AM
steeda007's Avatar
steeda007
Actually I have a Roushcharger in a box waiting to go in when I have a free weekend and was thinking that while I had the engine bay cleared, I should take a stab at the phasers (because they are noisey). What I would like to know is how invasive is the job? Does the front cover have to come off, or is it like the cam position sensor on the 4.6L Mustang motor (easy pull and swap)?
Thanks for the help.
Cheers
Old Jan 23, 2009 | 11:58 AM
98greensi's Avatar
98greensi
It doesn't appear to be too bad. i think if you can install a super charger you should be able to do the cam phasers. just need the timing tool. if you have high band internet (dsl cable etc) you can go to this site Automotive Technicians | Mechanics | Auto Techs | Auto Advice | Auto Tech Forums | Ford Techs | GM Techs | Chrysler Techs | Toyota Techs | Honda Techs | Nissan Techs | Volvo Techs | Land Rover Techs | Diesel Techs | BMW Techs | Volkswagen Techs | Lex scroll down. episode 17 shows how to remove the cam shaft so you can get a general idea whats it volved for the cam phaser minus a few things. episode 22 explains the noises etc of a 5.4 motor between what FORD calls normal and abnormal. also shows the operation of the VCT and cam phasers
Old Jan 23, 2009 | 12:13 PM
joonya's Avatar
joonya
hi there, i've beem looking at buying a 04-06 f-150 but everyone i look at has (what i thought we're noisy lifters) but from what your disscussing sounds like the cam phasers are what making all the noise is this a serious problem?
Old Jan 23, 2009 | 12:17 PM
98greensi's Avatar
98greensi
Joonya, If you goto the website above (scroll down to episode 22)and have decent speakers it will explain all the normal and abnormal noises of the 5.4
Old Jan 23, 2009 | 12:32 PM
joonya's Avatar
joonya
hey 98greensi, thanx very much, i will do so!! have a great one!
Old Jan 23, 2009 | 03:16 PM
steaks's Avatar
steaks
Very good post 98greensi. Episode 22 is very informative regarding the make up of the Cam phaser and the normal and abnormal noises made in the truck. Mine sounds similar to the lash adjuster noise which to them is normal. My issue is I don't want the noise. The acting is horrible but the information is great.
Interestingly, my wife has a 2005 Mercedes, don't get me started with the noises that engine makes upon start-up. But it runs like a scalded dog when you put your foot into it.
120mm Jedi
Nov 12, 2014 11:55 AM
brian931
2009 - 2014 F150
Mar 2, 2014 07:04 AM
hb2605
2004 - 2008 F150
Mar 20, 2013 08:10 PM
coobie
2004 - 2008 F150
Feb 25, 2012 08:40 PM
