solid driveline
Old Jan 22, 2009 | 12:46 PM
beardsly's Avatar
beardsly
solid driveline
Is there a solid driveline in the market for a 69 f-100 long bed anywhere or do i have to have one made? I would like to get rid of my two piece driveline so it has less of a chance of exploding when i drag race my beater wood hauler on the 1/8th mile and beat the little imports that show up.
Thanks, jason
Old Jan 22, 2009 | 01:16 PM
Unimog005's Avatar
Unimog005
just have one custom made....
I have the "mated" np453/205 in my 1967 F-250...it came from a 77-79 era truck...So I now have a long single Driveshaft to the back axle....I just gave the measurements to the shop and they had one made in about a day.
Old Jan 22, 2009 | 04:35 PM
52 F3's Avatar
52 F3
You have to have a slip joint somewhere in the d-shaft and I think the one in your two piece shaft is between the shafts. If so to a one piece shaft you will have to have a slip joint at the trans and that will require a different trans. output shaft and extension housing.
Old Jan 22, 2009 | 04:54 PM
wizzard351's Avatar
wizzard351
the one i had in my 71 when it was 2wd was out of an early 80's f100. it slid rite in the trans and with a goofy u-joint it fit the pumkin
Old Jan 22, 2009 | 09:13 PM
Ford_Six's Avatar
Ford_Six
They make slip joints for driveshafts, that's what the rear section of the shaft has. The one in the transmission rear housing is called a slip yoke.
Don't expect it to be cheap. Honestly, the one in there with new joints will be just as strong, and you would only need one strap.
Old Jan 23, 2009 | 09:50 AM
mongoosekeith's Avatar
mongoosekeith
I have a 79 f150 parts truck, so the solid d-shaft would work on my 69?
