My 96 has a 4407 with the flange like that one. I always thought 96 & 97 were the only years that used the 4407 but someone recently had a 95 with a 4407 so I guess that one could also be from a 95.
It's a E4OD from behind a 351W out of a F350. The T-Case is a BW4407.
I know that the transmission case isn't useable because of the different bell housings. What other inside parts are different?
I was planning on tearing this one apart, tearing mine apart and then figuring out between them which parts to use for the rebuild into a 4X4 transmission.
I'm probably going to get the $400 hard parts kit from BTS in addition to the "premium" friction rebuild kits. Anything else I should be doing for a transmission that's used to tow heavy behind a mostly stock 7.3?
converyters are different as well as number of clutches, the diesel has more for obvious reasons. the valve body/accumulator and solonoid packs will swap out unless yours or that one is an early 94-95 model and the other is later. but the solonoid packs are still the same
