Sponsored by: Real Truck
Fuel/Water Separator Drain Plug
Old Jan 22, 2009 | 07:30 AM
Headviking's Avatar
Headviking
Hi all. Hope someone can help me out with an upgrade. I just finished draining my fuel/water seperation filter. What a mess!!!! I found there is an upgrade to avoid this mess. http://www.forddoctorsdts.com/articl...icle-05-19.php Has anyone tried one of these and if so is it worth the money and where can I get one of these? I hope someone can help.
Old Jan 22, 2009 | 08:23 AM
HeavyAssault's Avatar
HeavyAssault
I got one, works great and you should be able to get them from the dealership.
Old Jan 22, 2009 | 08:48 AM
juneau76's Avatar
juneau76
A lot of guys have those and strongly suggest them. I put one in at my last filter change and the truck wouldn't run. To protect the engine, I re-did the procedure and put the OEM plug back in since it was the only change I made to the system. Next filter change, I'm going to put it back in.
Old Jan 22, 2009 | 09:08 AM
bradcollison's Avatar
bradcollison
One of the best mods you can do!! I drained my seperator last night, and I can do it with my mechanics gloves on, no wrench required.
I held a clear container up to the plug and it went into the small mouth jug without spilling a drop. The new plug directs the stream of Diesel right where you want it.
Old Jan 22, 2009 | 09:12 AM
jim6liter's Avatar
jim6liter
I put that on my truck.It works great.Then I took a 2 liter bottle and strategically cut it with a razerblade to fit right around the drain and 0 mess.
Old Jan 22, 2009 | 12:33 PM
Headviking's Avatar
Headviking
Thanks guys. I think I'll just print out the page and get one before my next fuel filter change.
Old Jan 22, 2009 | 02:58 PM
DCSpecial's Avatar
DCSpecial
How did you make a mess with the stock plug?
Just curious.....I've never had issues getting messing.
Old Jan 22, 2009 | 04:35 PM
rmosso1's Avatar
rmosso1
Tell me. This post is about the 6.0. I guess I am answering my own question because I still have a 5 mm allen wrench from my 2003. Then I thought the 2005 went to a 8 mm allen wrench.
My 2008 has a swing valve, but it is in the frame rail behind the suspension. I am going to the shop tomorrow. Maybe they will let me watch, and I'll report...
Old Jan 22, 2009 | 04:38 PM
DCSpecial's Avatar
DCSpecial
6mm for the 6.0 drain plug...
Old Jan 22, 2009 | 05:08 PM
jim6liter's Avatar
jim6liter
never really messy,just sometimes diesel would get on the driveshaft.
Coors Man
6.7L Power Stroke Diesel
Jul 18, 2015 08:41 AM
Ricohman
Jun 19, 2015 05:50 AM
Squeggi
6.4L Power Stroke Diesel
Mar 18, 2014 10:47 PM
RideDiesel88
Jun 19, 2012 10:32 AM
CLSE
Feb 22, 2011 05:45 PM
