headers installed-lost power
Old Apr 28, 2002 | 10:02 PM
bsmosk's Avatar
bsmosk
Post headers installed-lost power
hello all,
Just insalled Hedman headers and dual Flowmaster 40's on a 85 bronco with a 351-4bbl.
Sounds great at idle and low rpm run, but lost tremendous power at upper range and
pops bad out the tail pipes. I checked to make sure all vac lines are either attached
or plugged. system has no cats ( been gone for a year now), and was running real good before
header install. Havent welded in a crossover yet. Also no O2 sensor in pipe. Wasnt there when I
bought truck. Any input you can give will be greatly appreciated.
Barry
Old Apr 29, 2002 | 06:32 PM
sauerf100s's Avatar
sauerf100s
My guess is your truck is running lean now. More air/exhaust out means you need more air/fuel in. It wouldn't hurt to check the timing too.
Old Apr 30, 2002 | 12:55 PM
bsmosk's Avatar
bsmosk
I fixed the problem. I am the greatest mechanic ever. The problem was multi faceted. I found a bad cxo bypass valve and a stuck inter-electronic shunt positioning relay module socket adapter casing. I bore tested the phrasmatic extractor to make sure it was outletting .008965 ohms and realigned the vacuum controlled compression diaphram inlet exhaust occilator to EXACTLY .0045913770831279 of an inch. That's all. Done. Finished. Runs like a champ. Uhhh....actually I wish I were that good. In reality I crossed # 2 and 3 spark plug wires. STUPID mistake...duhhhh. Sorry I called an air strike for something so blatent. I will however begin saving up $70,000 to buy you ALL a cup of coffee. Thanks again. bsmosk.
Old May 1, 2002 | 06:15 AM
fatdaddy's Avatar
fatdaddy
NOOOOOOOOOOw we know why your website name is ----bs-----and before you take your girlfriend out in your truck , make sure the Fart Extractor and the bs filter are working properly!!!!!!At least you were smart enough to solve your own problem--and did---I usually just let my friend the "mechanic" do it---good luck , fd :-X11
Old May 1, 2002 | 06:27 AM
fatdaddy's Avatar
fatdaddy
barrycm
Jul 11, 2011 09:14 PM
RabidJade
Dec 15, 2010 09:46 PM
bsmi16490
16
Mar 12, 2007 07:51 PM
Almost_A_Merc
Feb 25, 2005 10:34 PM
muskin1
Dec 3, 2002 10:41 PM
