EEM
Old Jul 11, 2011 | 07:30 PM
barrycm's Avatar
barrycm
EEM
1990 F150 5.0 E04D
My ground cable shorted out burned the small wire grounded to the frame. Noe my engine is running like a POS won't idle and NO power. I'm wondering if I may have blown the EEM module or the computer. How do I test the EEM it has two holes on either side says TEST
Thanks Barry
Old Jul 11, 2011 | 09:14 PM
andym's Avatar
andym
So can we assume that you fixed the ground problem and all the electrical connections now work as they should?
There are a bunch of failure modes for the PCM. One, it will run the fuel pumps continuously. Two, it won't light up the CEL light. Three, it won't let you pull codes. If your PCM doesn't do any of those, it's probably fine.
Bmcush
Feb 15, 2014 11:27 AM
Josh Longmire
Jan 30, 2011 09:41 PM
tjoegrind
Nov 5, 2007 05:12 AM
JKBridges
Sep 23, 2002 09:34 PM
BB
User Gallery & Picture Display
Aug 31, 2002 11:49 PM
