Intercoolers
Old Jan 21, 2009 | 07:14 PM
69 stang's Avatar
69 stang
Intercoolers
I have a cooler but working on one for a buddy. So I been looking at coolers and notice that some coolers (aluminum ends) the inlet and outlet look like they are at the same height. But the ones with the plastic ends are offset. Am i seeing things wrong or is there a reason as to why they are different.
Old Jan 21, 2009 | 07:24 PM
pjwoolw's Avatar
pjwoolw
I think the plastic offset ones are from 6.0 trucks. I guess should know since I have one. But have only seen pictures on the Banks site on ebay. Though I have seen a 7.3 cooler that had plastic ends. At least that was how it was described.
Pete
Old Jan 21, 2009 | 07:31 PM
69 stang's Avatar
69 stang
thats what i was thinking that the 6.0 was offset only. but i've seen some sites that show the 7.3 with plastic ends being offset.
Old Jan 21, 2009 | 08:16 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Till I had read the 7.3 are all aluminum and same size of the inlet and outlet, and the 6.0 have plastic tanks and ofset in the lines.
Old Jan 21, 2009 | 09:37 PM
69 stang's Avatar
69 stang
i know the tube sizes are different between the 7.3 and 6.0 outlet but the height of the inlet and outlet from the base are they the same for both the 7.3 and the 6.0 cooler?
Old Jan 21, 2009 | 09:40 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Sorry I really dont know, I misunderstood your question.
Old Jan 21, 2009 | 09:55 PM
BlueMule's Avatar
BlueMule
Jose
For the 1st few years the SD coolers were all aluminum and I believe it was on the 01's that they switched to plastic end tanks.
Old Jan 22, 2009 | 09:21 AM
Neal 97 250's Avatar
Neal 97 250
I have a 6.0 cooler
Plastic tanks
both inlet and out let are the same height
Inlet is 3"
outlet is 3-3/8" I believe
Old Jan 22, 2009 | 09:44 AM
BlueMule's Avatar
BlueMule
On a 6.0 IC the inlet and outlet are at different heights.
Stock 6.0
Tapercore 6.0
7.3 with inlet and outlet at the same height
Old Jan 22, 2009 | 11:41 AM
69 stang's Avatar
69 stang
so would i be right in assuming that all 7.3 coolers the inlet and outlet are at the same height or only ones with the aluminum ends?
Old Jan 22, 2009 | 12:56 PM
Neal 97 250
Well shazam! They are different heights. I naver noticed it even when I was installing it.
Hmmmm...
Attention to detail Neal.
Old Jan 22, 2009 | 04:14 PM
don77's Avatar
don77
i have questions about coolers could you use a smaller one like there saling on ebay or does it have to be that big as them pictures
Old Jan 22, 2009 | 04:32 PM
tjbeggs's Avatar
tjbeggs
Gotta be big enough to flow the air needed. The only one that I have seen that can flow the air needed is hypermax's OBS kit but I am all for bigger is better! That's why I am overweight....
Old Jan 22, 2009 | 04:47 PM
cowmilker08's Avatar
cowmilker08
so your suggusting the hypermax kit. how much does this run?
Old Jan 22, 2009 | 05:54 PM
don77's Avatar
don77
oh i understand now so little one really would do much 25L x14Wx3 is to small
