headlight removal
Old Jan 21, 2009 | 06:00 PM
Kez's Avatar
Kez
headlight removal
How do i remove the whole headlight? not just the bulb?
Old Jan 21, 2009 | 11:05 PM
Scndsin's Avatar
Scndsin
See if you can sift some info out of this thread:
https://www.ford-trucks.com/forums/7...t-95-f150.html
Its mostly about adjusters, but has removal info as well. I just happened to be looking at it. If not enough, there's always the search.
Good luck.
Old Jan 22, 2009 | 09:03 PM
Kez's Avatar
Kez
i've figured out how to get it off..there are two clips on the top (and one on the bottom) that i cant figure out..is there some special tool i need to get those off?
Old Jan 23, 2009 | 06:41 AM
Scndsin's Avatar
Scndsin
The plastic blocks that the adjuster screws go into twist into the back of the housing. Is that what you are calling clips? I described how I removed them in my post.
Originally Posted by Scndsin
Take the headlight assy with the adjusters attached & place it face down on a towel. Take 2 small pocket style flathead screw drivers and carefully place them under the tabs that are just past the "ramps" of the "bullet thingey wings". Twist that counter-clock wise with a pair of needle-nosed pliers. The screw drivers lift the tabs/wings above the ramps allowing the wings to get past the ramps.
Putting them back is much easier. Just make sure you put the right ones back in the top & the flat sided one in the lower corner. Lube the rubber mounts to save your arm & the head of the adj screw.
Hope this helps.
Old Feb 2, 2009 | 08:56 PM
Kez's Avatar
Kez
haha thanks. more internet issues. i just now read this helpful piece of material. it took me four hours to finally get them out and fixed >.< but boy do they look good!!
Old Feb 2, 2009 | 09:51 PM
Sportruk's Avatar
Sportruk
Nevermind. I need to learn to read. Didn't realize you got it.
