4"-6" Lift?
You will want to start looking into stainless braided brake lines.
You will also require some sort of steering correction. The drop pitman is a start, a raised steering arm is an option, but x-over steering is the way to go.
MAy also have to disconnect the parking brake cables from the frame so they can have a little more stretch.
Diff vents may need to be lengthened when you get to 6 inches and up.
Many thicknesses are available, and while it is fairly expensive, it is the least expensive type before you get into seemless. DOM is not seemless.
True seamless tubing is another matter. This is made by taking a billet of steel and piercing it with a "bullit shape" to form a tube. This is expensive tubing as you can imagine.
Another option is a high tensil strength tube like 4130. 4130 , normalized is similar to DOM in yield strength , but a higher ultimate tensile. The real advantage is the capability of being heat treated to much higher yield and ultimate tensile strengths.
I now use the 4130 variety. You must Tig this by the way.
You will have to decide whether or not you will actually use weld in inserts or use a wall thickness large enough to just tap the tube. This is an option and probably the easiest.
Then you must decide whether to use tie rod ends, or spherical rod ends. DOnt get cheap here, this is your steering.
Chebby 1 ton TRE's are only about 50 bucks each, and 1.25" chro mo rod ends run me about 125.00 each.
Just cant be too safe here.
I have found that it is less expansive to purchase a steering arm. I have the ability to make them, and have made them and for the amount of work it requires, ie easier to just purchase.
Perhaps I was not the clear one here.
For a 4" kit, you will have to do nothing, except for lifting the truck.
Even at 6 inches you have minimal work, and zero to the drivehshafts.
The only possible mod, would be to the driveline angle.
Now, the steering correction will have to be made for either lift.
Usually just a drop pitman will be fine, if x-over is not in the plan.
For either lift make sure that the brake lines reach. You can modify stock lines, but aftermarket lines are highly suggested.
Is that a little more clear?
Maybe not the rear but deffenitly the front.
When I first put my 4" springs in front (1979 F250) when I would take off from the line in 4x you could literally "feel" the u-joints on the front axle d-shaft binding. You'll have to shim it.
Good questions.
First the drop pitman arm.
Whichever kit you choose to purchase, will offer and even suggest the correct steering correction for your ride. In fact, they will make it an option for your ride.
This will require a suitable pitman arm puller and a big hammer, to remove. The correct puller will make easy work of this.
Difficulty is based upon your tool. Cheap tool might take all day. Correct tool will make this easy as pie.
To adjust your driveline angle, a wedge will have to be installed under the leaf spring. This will fit between the leaf and the spring perch, and depending on how much axle, or pinion angle is required, will determine how thick the wedge should be.
You should expect approx, 4 to 6 degrees for the above lift. There are many variables here, so you will have to determine this after the kit is installed.
) Easier...............................it depends on your wrenching ability. But a vehicle like you have is a good place to start for even a novice. It has a fairly simple suspension and if you get your hands on some decent hand tools, a good floor jack and some good jack stands your well on your way.
If you do decide to do it on your own remember to BE SAFE, there are no second chances!!! Don't rely on a jack to hold up a vehicle, support it properly (jack stands) and double check that is supported properly. Also if you decide to do it yourself and you run into a problem you can always ask here for help
Take some advice and don't make a deadline for yourself. Things will go wrong and it will take longer than you think! I promise. I remember last new years we put a 6" lift in my cousins Bronco, took off work Friday so we could take it upstate for the weekend for New Years, Our plan was to leave Friday night...... well we made it up by midnight Saturday. So my only point, take your time, don't rush and have fun.
