4"-6" Lift?
Old 01-23-2009, 10:42 PM
YoungFordAddict66's Avatar
YoungFordAddict66
YoungFordAddict66 is offline
Originally Posted by kc 300EX
Doing it yourself is definately the way to go. If you don't have any experience and don't know what you're doing, PERFECT! There's really only one way to learn and that's to get out there and do it.
Take some advice and don't make a deadline for yourself. Things will go wrong and it will take longer than you think! I promise. I remember last new years we put a 6" lift in my cousins Bronco, took off work Friday so we could take it upstate for the weekend for New Years, Our plan was to leave Friday night...... well we made it up by midnight Saturday. So my only point, take your time, don't rush and have fun.
how much did it all cost you? like steering, lift kit, other parts?
Old 01-23-2009, 11:14 PM
kc 300EX's Avatar
kc 300EX
kc 300EX is offline
The Bronco lift was about 500 bucks with shipping off ebay. It was a 91 Bronco we lifted. Came with springs, drop brackets, add a leafs and a 4" block for the rear. Also came with a drop pitman arm. Not the highest quality lift I've ever seen. Had some crazy camber problems. I wouldnt reccomend it. Id go with a more expensive Sky Jacker lift.
Old 01-25-2009, 06:52 AM
pinkpanther's Avatar
pinkpanther
pinkpanther is offline
I just put on the pro comp super duty 6.5'' front springs and my front drive shaft is 1 1/4'' from even touching the yoke fully extended. Pinion angle needs changed and will still have to get shaft lengthed. Any body else have this problem with these springs? How much do they move the axle forward? I can shim the axle a little bit but will be limited due to the u bolt going though front axle. Any help would be appricated.
Old 03-27-2010, 09:32 PM
abriel68's Avatar
abriel68
abriel68 is offline
hello i had a question dont mean to hijack this thread just figured i could keep it going, i just got 6" springs for my 99 superduty, i want to put them on, besides longer ubolts and maybe shiims, breaklines, will i need to lengthen driveshafts also why do i need another pitman arm i have crossover steering so shouldn't it be fine without buying a new one? thanks for any info.
Old 03-27-2010, 10:46 PM
mark a.'s Avatar
mark a.
mark a. is offline
Originally Posted by YoungFordAddict66
im wondering what ajustments to my drive shaft or steering etc. i will have to make to my 78 f250 4X4 camper special. any help and edvice is much aprreciated.
Your front shaft will have to be lengthened for a 4" or a 6" lift. You will be getting real close to having to cut a chunk out of the trans crossmember at 6" for shaft clearance. The back shaft will probably have to be lengthened to be reliable as well. For 4" to 6" you might be able to get away without it for a while if the slip yoke is in real good condition & your not beating on it.
Mtnhermit
1999 to 2016 Super Duty
04-30-2016 12:57 AM
atillett
10-22-2007 09:24 PM
Schmitty
1997-2006 Expedition & Navigator
07-01-2004 11:45 AM
rustyolred27
06-20-2003 10:50 PM
Quick Reply: 4"-6" Lift?
