intake manifold
Old Jan 20, 2009 | 09:50 PM
whatthencuz's Avatar
whatthencuz
intake manifold
i have an 83 302 v8 and i bought the weiand 7515 intake and im planing on buyin an edelbrock 1406 carb, do ya think i should get a performance cam also? if so what kind?
everything on the motor is stock except for the edlebrock air intake wit k&n filter
Old Jan 21, 2009 | 12:03 AM
Franklin2's Avatar
Franklin2
That's the wrong manifold for your truck. You are not going to like it. You should have gotten a dual plane intake. What tranny and rearend gear do you have?
Old Jan 21, 2009 | 12:46 AM
whatthencuz
i have a c6 tranny and i dont know the rear end
Old Jan 21, 2009 | 10:18 AM
LARIAT 85's Avatar
LARIAT 85
I agree with Franklin. That manifold is wrong for your truck. You will be much happier with a dual plane intake manifold. The single plane you picked out is for drag racing, when top end power is what you are after. With that manifold, your bottom end torque is really going to suffer. And with a little 302 in a heavy truck, you need all the torque you can get!
The Edelbrock 1406 carb is okay though. I think the 500 cfm will be a better match for your needs, though.
Old Jan 21, 2009 | 10:57 AM
Redneck1465's Avatar
Redneck1465
Hate to hijack this thread but I am going to rebuild my 351W this summer gonna run a ZF 5spd with a 3.50 rear end. Should I get a dual plane intake and about 600 CFM carb for the best low end torque and power?
Old Jan 21, 2009 | 02:37 PM
whatthencuz
i appreciate all the responses. ya think a weiand stealth intake would be better?
and say i do keep this 7515, do ya think if i put headers, cam and performance distributor will help it out?
Old Jan 21, 2009 | 02:42 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://performancedistributors.com/forddistributors.htm
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Jan 21, 2009 | 05:20 PM
LARIAT 85's Avatar
LARIAT 85
What are your intensions for your truck?
Be REALISTIC. Are you going to race your pickup truck with that little 302 motor in it?
If you are not going to race with it, you DO NOT want a single plane intake manifold.
YOU WILL BE MUCH HAPPIER WITH A DUAL PLANE INTAKE MANIFOLD.
But it is your truck. Do what you want with it, but don't say I didn't warn you!
Old Jan 21, 2009 | 11:00 PM
whatthencuz
lol nah i know better than racing my extended cab truck wit 22" rims wit that little motor. my carburetor is goin out so i wanted to replace it with the edelbrock and i needed to change my intake so i wanted to upgrade my existing one. the reason i got the weiand intake cuz i got it cheap on ebay but if its not the right one i can just sell it. i was lookin at some intakes on summit and i came across the weiand stealth and the summit stage 1 and 2 ( all 3 have dual planes)
Old Jan 22, 2009 | 12:12 AM
Franklin2's Avatar
Franklin2
You are on the right track now with those manifolds. I would stay away from the stage 2 manifold though. It says 1500rpm and up. Stick with the ones that say they make power from idle -up.
Old Jan 25, 2009 | 07:38 PM
whatthencuz
ok thanks i appreciate everyones help
lemasters f100
Jan 16, 2014 08:49 PM
fancyvern
Sep 26, 2012 12:37 AM
mainman
2004 - 2008 F150
Dec 31, 2009 08:11 PM
Bigblockexplorer
Feb 2, 2008 02:09 PM
fordeverpower
Jul 1, 2005 05:17 AM
