Rpm range
Old Jan 25, 2009 | 10:31 AM
Ritechous_23's Avatar
Ritechous_23
Rpm range
I put a aftermarket tac in my 85f-250 and wondering the rpm range at 75mph.This tac I'm using has been in my firebird,trecel,and now my truck.I droped the tac on the ground and may have damaged it.My truck has the 4 bbl 460 with c-6 tranny with 4:10 gears and also a 4x4.When I driving my truck 75mph on I-44,my tac says 2500 rpms.Does anyone with a truck like mine run the same rpms?
Old Jan 25, 2009 | 04:31 PM
srercrcr's Avatar
srercrcr
Not even close. Should be around 3800.
At 75 mph the engine should be pretty much roaring.
Old Jan 25, 2009 | 05:45 PM
bashby's Avatar
bashby
https://www.ford-trucks.com/calculat...php/p-mph_rpm/
Get your tire diamater at tirerack.com by looking up your size and looking at tire specs
Old Jan 25, 2009 | 08:01 PM
Freaksh0w's Avatar
Freaksh0w
Definitely must have damaged your tach. It's off by a thousand+ RPM. Unless you are running some 44" mudders you didn't mention :-)
Old Jan 25, 2009 | 08:18 PM
Ritechous_23
I cant here my engin.The axel code for my truck is 73 and trans code is k and the tires are LT235/85/R16
Old Jan 25, 2009 | 08:30 PM
86bigred's Avatar
86bigred
sounds like you have 355 gears,my 460 4speed runs close to that rpm at the same speed , but mine is 355 or 350 gears, can't remember exactly. you have the same size tires i do to, are you sure the previous owner didn't change the diff gears.
Old Jan 25, 2009 | 08:53 PM
84tealbeast's Avatar
84tealbeast
gees my truck at 75 mph runs close to 5k,lol i cruise at 45 at 3krpm
Old Jan 25, 2009 | 09:22 PM
Ritechous_23
Everything looks stock.The previous owner is a farmer and the the truck was used as a farm truck for the last 23yrs.I guess I'll buy a new tach and see what that says.
Old Jan 25, 2009 | 09:25 PM
Dean88's Avatar
Dean88
It should read about 3K maybe 3200, or thats what my 88 F250 with a C6 and 4.10 runs at anyway, and thats also what my 87 ran with a 4spd and 4.10's
Bootzz711
Dec 7, 2011 11:28 AM
screaminm5
Jan 5, 2011 12:58 PM
gummybear918714
19
May 24, 2010 11:53 PM
Radioace
Bronco II
Aug 14, 2004 04:55 PM
