bracket modifications
Old Jan 20, 2009 | 09:10 PM
Nighte51's Avatar
Nighte51
The front leaf spring front brackets are somewhat worn (not surprising since they are old and used). Where the hangers attach to the brackets, it is angled as if the bolts had been loose and the hangers hung at an angle. The top of the bracket sticks out from the frame approx. 1/8" and the bottom sticks out approx. 1/16" to 1/32" (I have attached a pic - a little blurry). Is it okay if I grind this area down so that everything is flat?
[IMG][/IMG]
One more question. When I get ready to put the bushings (brass?) in the brackets, do I need to put a little grease on the bushings before I install them? I assume I do.
Old Jan 21, 2009 | 01:25 AM
Julies Cool F1's Avatar
Julies Cool F1
Good Question!
I'm not sure. But AX Racer would know.....Bump to top!
Julie
Old Jan 21, 2009 | 04:59 AM
jaye's Avatar
jaye
Personally I wouldn't grind the bracket down due to it may be weakened. Your best bet is to purchase new brackets if the hole is misaligned the new bushings will be formed to the out of round shape and be ruined pretty fast. If you had rivets holding the brackets in they more than likely were loose. When I took mine off the pbrackets were so loose you could shake them with your hand the bracket had also worn into the frame from the shifting.
Old Jan 21, 2009 | 05:20 AM
AXracer's Avatar
AXracer
I don't have much experience here, but my mantra for suspensions is to replace any worn parts with new.
Old Jan 21, 2009 | 08:06 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I can't really tell what that pic is of (cell phone camera?) but if I understand correctly, you're saying the part of the bracket with the bushing sticks out past the frame? If so, I think that is correct, it is so the shackle clears the frame when it swings.
Old Jan 21, 2009 | 08:51 AM
jaye's Avatar
jaye
The picture is bad I was looking at the thickness of the bracket itself just below the bolt head, can't figure out what's in the background.
Old Jan 21, 2009 | 09:14 AM
55 f350's Avatar
55 f350
whats it too ? what year ???? i know someone who is taking apart his bonus built for a frame swap , so he has the oem frame still i beleive , he's in arkansas and i can ask him , or if it's to a 53-56 i got a set that weren't to bad here from a parts truck ...............
Old Jan 21, 2009 | 12:59 PM
Nighte51's Avatar
Nighte51
Sorry... I was dead tired when I posted. The pic is of the front leaf spring front bracket on the pass. side of a 51 F1 (the black mass in the middle of the pic). The hole for the bushing is not worn. That is pretty round. Albuq, you're correct. I know it is supposed to stick out for the shackles to miss the frame. The problem is that the part that DOES stick out from the frame is worn at an angle, which means that if I attach the shackles, they will most likely hang at an angle. I know I do not need to grind it flush with the frame, just enough for the shackles to hang straight. That is my dilemma whether I should or not.
And to all who say buy new brackets, well I have tried and unless someone has started producing new ones in the past six months to a year, then that is not an option because no one carries new ones. Now, if someone knows something that I don't as far as brand new brackets, please let me know.
Old Jan 21, 2009 | 01:13 PM
gusso's Avatar
gusso
You know, I don't quite understand the problem here, but when I hear the word angle
regarding front springs and brackets I think of wedges that may have fallen out. Don`t know if wedges were used on `51s or not. Just a guess. Good luck with it.
Gary
Old Jan 21, 2009 | 02:01 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Mine were worn unevenly like that, too, but not quite so much. I'm pretty sure the brackets are cast or forged steel, and can be welded on. You may be able to lay down a bead and grind it back to square. Maybe someone has tried welding on these and can confirm? Otherwise, you would have to grind square then use a washer-like piece to make up the difference. On the other hand, if you are replacing the bushings, they will hold the shackle square regardless of the shape of the bracket.
I think JobLot sells the brackets, or did about 6 months ago.
Old Jan 23, 2009 | 05:58 AM
needhelp49's Avatar
needhelp49
https://secure25.securewebsession.co...shop/index.htm
there right here 25 bucks each
Old Jan 23, 2009 | 07:10 AM
AXracer's Avatar
AXracer
If it hasn't been said enough before, welcome to FTE and the 48-60 forum, the most helpful place on the web!
9.ford.5
Offroad & 4x4
144
Jan 15, 2022 07:25 AM
cowboybootlegger
18
Sep 3, 2015 08:39 PM
rpxr400
2004 - 2008 F150
Sep 28, 2008 07:24 PM
stargazer
Dec 29, 2003 08:20 PM
nvreloader
Sep 19, 2003 02:02 PM
