Sponsored by: Real Truck
Towing Question
Old Jan 20, 2009 | 04:11 PM
wfa0002's Avatar
wfa0002
5th Gear
Towing Question
Idiot question here but I just got an 08 f250 about a week ago. The other day I hooked up the boat and was backing in the driveway and the backup sensors were going off the entire time I was in reverse. Also the message center said that no trailer was connected. This is the only thing ive towed so far, I tried to read in the manual but i didnt find what i was looking for. How do you know if the truck is registering that the trailer is connected? I appreciate any help. Thanks
Old Jan 20, 2009 | 04:16 PM
Bigskyduty's Avatar
Bigskyduty
As far as the back up sensors go, there is a button in the middle of the dash to push when backing with a trailer to turn off the alarm, should be lableled RSS I think. Im no help with it not registering your trailer tho. Someone will chime in im sure.
Old Jan 20, 2009 | 05:02 PM
barrelhorses's Avatar
barrelhorses
Maybe this is a stupid question....but did you have the trailer plugged in to the truck? If so, are you sure it was plugged in correctly?
Old Jan 20, 2009 | 05:27 PM
Beerstalker's Avatar
Beerstalker
Make sure your trailer wiring matches up correctly with the wiring schematic on the plug on your truck. I think there is 2 ways to wire up the plugs and some trailers are wired differently. Otherwise it is most likely your ground on the trailer isn't good enough and the brake controller isn't getting a good signal from your brakes on the trailer.
Old Jan 20, 2009 | 05:32 PM
skip mitchell's Avatar
skip mitchell
my 06 I put one of the tripple ball recievers in the hitch ,it was painted,no ground,lights didn't work,tow command didn't reconized the trailer till I buffed the paint off it.
Old Jan 20, 2009 | 05:46 PM
rrrrick's Avatar
rrrrick
Your trailer wiring has a ground wire, so you shouldn't have to worry about getting a ground through the hitch, if you did, check that your trailer is wired properly
Old Jan 20, 2009 | 05:49 PM
bpounds's Avatar
bpounds
Just turn off the backup sensors. I guess Ford could have automatically disabled them when a trailer was connected, but they didn't. Some guys actually use them to help line up their hitch. Anyway, just push the disable button.
As far as the TBC not finding the trailer, it could be trailer wiring as noted. It could also just be water/snow in the plug receiver. This has been noticed by others, particularly during the winter. And this is a boat?
Your trailer should NOT be grounded through the ball. It should be grounded through the plug If you had this problem then you had a bad ground somewhere else and sanding the paint off the hitch just disguised the real issue.
Old Jan 20, 2009 | 05:54 PM
dchamberlain's Avatar
dchamberlain
Does your trailer have brakes? The TCB won't show a trailer connected unless it does. I've towed boats up to 21 feet that didn't have brakes on the trailer.
Old Jan 20, 2009 | 06:03 PM
bpounds's Avatar
bpounds
True, but I don't think you would see the "no trailer connected" message. That is supposed to be a fault message - I think. When I pull my little utility trailer, no brakes, the TBC does not even turn on. Mine is an '06 of course, and the OP has an '08.
Old Jan 20, 2009 | 07:29 PM
powerstroke72's Avatar
powerstroke72
Well, you beat me to the punch. On my '05, the message center doesn't indicate the trailer unless you manually squeeze the gain control on the TBC. If you do that, the message center says no trailer detected or something like that. This is when using the 4 pin connector for my utility trailer which of course doesn't have brakes.
Old Jan 20, 2009 | 07:48 PM
shorebird's Avatar
shorebird
Does your boat trailer have a 4 pin or a 6 pin connector? 4 pin = no trailer brakes I personally do not know of any boat trailer that has electric brakes. It sucks when you submerge electric brakes in saltwater or even fresh water. No electric brakes = no connection signal.
Old Jan 20, 2009 | 07:53 PM
FarmingFord's Avatar
FarmingFord
Thats what my uncles 08 F350 says sometimes when we tow this old junky trailer. We think it is just a bad connection because it comes on for a while then goes off. Hope you find out whats wrong.
Old Jan 22, 2009 | 08:43 AM
wfa0002's Avatar
wfa0002
5th Gear
Thanks for all the replies. I found the back up sensor button so that issue is solved. Pretty annoying when youre backing up and its beeping the whole time. The trailer is a 5 plug adapter, and the trailer has brakes. If im backing up with a 4 plug adapter, the brakes lock. I remember now, like powerstroke72 said, the message center said something like "no trailer connected" when i slid the gain control. Im in texas and its been pretty warm so i pulled the boat out the other day, so no snow or water. Maybe the truck is registering that the trailer is back there? I guess Im just not sure if the gain control is working. I ste it to ten and then to zero and couldnt tell any differences, this is why i think its not registering. Thanks.
Old Jan 22, 2009 | 10:19 AM
12ozd's Avatar
12ozd
There is no brake signal wire on the 4 wire flat plug.
Something isn't wired right,or bad adapter.
Old Jan 22, 2009 | 10:21 AM
redford's Avatar
redford
FTE Leadership Emeritus
Your trailer wiring or the adapter is screwed up.
Install a 7 pin connector on your trailer, wired just like the diagram rrrrick posted above.
