Nuetral safety switch
Old Jan 20, 2009 | 11:41 AM
raerjim's Avatar
raerjim
I have the column out of a 77-79 F 150, I believe. The truck will start in gear. Is the nuetral safety switch in the column up around the gear indicator, as I think? Do I just go to my LPS and for a new safety switch? How is it installed? Thanx in advance.
Old Jan 20, 2009 | 11:51 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/77 Steering column is the same, 1978/79 is different.
NSS
1965/77: C7TZ7A247A (Motorcraft SW600) / Mounted at the bottom of the steering column.
Activated by a Y shaped NSS selector lever (DOTZ7B097B) that snaps into the shift tube thru a slot in the mast jacket.
This lever is spring steel, the pointed end of the lever is notorious for snapping off, rendering it useless.
1978/79: On the transmission.
D8TZ7A247A .. (Motorcraft SW1489) / Use with C6 transmission.
D8TZ7A247B .. Motorcraft SW1491) / Use with C4 transmission
Old Jan 22, 2009 | 07:23 AM
raerjim's Avatar
raerjim
Thanks, Bill. Unfortunately, I am guessing at the year of the column installed by PO. Is there a way to i.d the thing? Tranny is FMX (cast iron case)
bronco6767
Jan 24, 2015 08:04 PM
Charles77f150
Nov 24, 2014 06:44 PM
raerjim
Jul 20, 2009 12:12 PM
47namrrapom
Feb 20, 2008 11:54 AM
jenkinsj
Electrical Systems/Wiring
Aug 7, 2005 07:47 PM
