Common front end problems
Old Jan 19, 2009 | 04:28 PM
SUPERDUTY OUTLAW's Avatar
SUPERDUTY OUTLAW
What are the common front end problems on these trucks. Mine is starting to make all kinds of damn noise when turning at low speeds don't have any clue what to even look for under their. Some ideas would be great.
Old Jan 19, 2009 | 04:30 PM
HKusp's Avatar
HKusp
What kind of noises Deven? Is it a thumping noise, is it only when turning? Etc.
The most common 2 things that I see are sway bar bushings and Ball joints.
Old Jan 19, 2009 | 04:42 PM
SUPERDUTY OUTLAW
Its kind of hard to describe kinda sounds like a creaking.
Old Jan 19, 2009 | 04:44 PM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
Powersteering pump? LIke a whineeeeeeeee
Old Jan 19, 2009 | 04:58 PM
87 F-150 I6's Avatar
87 F-150 I6
You might have bad hub bearings. Jack the front end the of truck up and see how much up and down play the wheel has, it really shouldn't have any. This is how I found out I had a bad hub assembly.
Old Jan 19, 2009 | 05:06 PM
fxstbchopper's Avatar
fxstbchopper
Creaking sounds usually come from bad ball joints or tie-rod ends.
Old Jan 19, 2009 | 05:39 PM
SUPERDUTY OUTLAW
Hell with my luck its probably all of the above i will check into the suggestions
FromaFord6
33
Aug 16, 2015 08:08 AM
StephenV
Sep 17, 2014 01:41 AM
cdichiar
15
Jun 30, 2014 10:53 PM
JIM ROLAND
Dec 22, 2007 03:21 AM
dieselbogging
20
Nov 26, 2006 06:46 PM
