PB dual MC conversion
eBay Motors: 1955 1956 FORD TRUCK UNDER FLOOR BUDGET BRAKE BOOSTER (item 120364381612 end time Jan-22-09 21:20:21 PST)
then there is this one where you use the original pedal
eBay Motors: 1953-1956 FORD TRUCK BRAKE BOOSTER UNDERMOUNT BOLT IN (item 290266487823 end time Feb-05-09 14:25:49 PST)
Thoughts, recomensations?
(We just would not tell anyone they are Ch3&y parts).
Thanks
My input; I would say that the “cheap” one would be OK, not too sure about the custom fit information, kina looks a little like a universal fit to me, look up MBM brakes (dealer only) universal one, they have a nice site.
MBM Disc Brakes
I went with the 7 inch booster universal with the petal assembly, probably the same unit, Pirate Jacks has this for $ 199.00. I have previously installed the MC/booster only and used the old petal on a 37 Ford coupe and the old linkage left a lot to be desired, a whole lot.
“but being wrong sure keeps me humble”
If I had the f-100 I'd be going disc and probably a firewall mounted unit. The f-350 will be basically stock with just some upgrades for safety's sake. With the stock gearing it will be straining to get much past 50 (but with the 1 ton, you see, I would only have to make half as many trips).
Thanks a ton.
Stay tuned, when it warms up here, I will undoubtedly have more questions related to the new plumbing (e.g. check valve or no, etc.)
