NO start condition..
Old Jan 19, 2009 | 05:29 PM
Fomoko1's Avatar
Fomoko1
Thanks for all the replies.
Thanks for the info on the vacuum pump.
No alarm system, I`ll check the fuses, charge the batteries, the jump the starter relay terminals then try tapping the starter if I can get at it.
No sign of any mice activity but who knows....
Old Jan 20, 2009 | 12:40 PM
96sherm's Avatar
96sherm
any luck today Fom??
Old Jan 20, 2009 | 01:02 PM
Fomoko1's Avatar
Fomoko1
I haven`t tried anything yet, I hope to later today or tomorrow.
Old Jan 22, 2009 | 06:32 PM
Fomoko1's Avatar
Fomoko1
The batteries tested ok in a load test.
I talked to a Ford tech and he pointed out that some of the things it could be.....neutral start switch, starter solenoid, wiring.
I haven`t tried to tap the starter solenoid yet, if it`s not that then on to it`s nightmare city.
Old Jan 22, 2009 | 06:44 PM
brickie's Avatar
brickie
The passengers battery is wired to the starter.I hope for you it's a loose wire or corrosion between the two and ground.
Old Jan 22, 2009 | 06:47 PM
Fomoko1's Avatar
Fomoko1
Thanks for the tip, I want to try everything I can before having it taken to the dealer, at $100 plus an hour labour rate it ain`t going to be a good thing!
Old Jan 22, 2009 | 06:54 PM
brickie's Avatar
brickie
It's $145 Hr in Canmore, good place to have friends when you need them,though its hard to makes friends with someone who rapes ya.
Old Jan 22, 2009 | 07:07 PM
Fomoko1's Avatar
Fomoko1
I know the service manger abit so hopefully that may help, he`s comes back to work tomorrow.
No matter as I love this truck so I`ll bite the bullet if it comes to that though it`ll be after it warms up and I need it.
Old Apr 27, 2009 | 09:32 PM
Fomoko1's Avatar
Fomoko1
An update and a good tip to remember.
Since it`s sorta spring here I finally I talked to a good Ford diesel tech from our local Ford dealership that told me to hit the power door locks afew times.....that did the trick, as soon as I did that the starter cranked right up, truck running like a hound!
From what I gather is the computer thought that the truck was being stolen and wouldn`t engage the starter circuit.......DOH! Seems this happens at the dealership`s lot too.
I`m all smiles now.....Big ones!!!!!!!!!!!!!
Old Apr 27, 2009 | 10:08 PM
FlyCanadianGuy's Avatar
FlyCanadianGuy
Wow thats awesome, and a QUICK FIX! :P I was thinking anti-theft or blown fuse from you charging the batts.
Old Apr 27, 2009 | 10:14 PM
Fomoko1's Avatar
Fomoko1
Looks like it was the anti-theft all along......
That leaves getting my 92 F250 to start better now, seems there is a tiny bit of air entering into the fuel system, possibly from the fuel filter bleeder valve or somewhere else, so it makes for a hard start condition. Once it`s started in the morning it`ll fire up instantly all day long and run fine......
