e4od Help!
Old Jan 18, 2009 | 03:51 PM
rob rosencrans's Avatar
rob rosencrans
e4od Help!
Hi, I am a newer member but i am in need of some help. I have a 94 F150 with a 302, I just put another trans in it, E4OD, to replace the bad one. The new one was rebuilt about 1 year ago and looked clean. We had to remove the shift shaft and swap it out with my old one for the linkage to work and I am confident that it was done right. Here's the catch, The truck will not shift, I have reverse and can put in in drive and it will go but not get out of 1 st gear. If I manual shift it it goes from 1st to 2nd fine but when I go to drive it it shfts into I guess neutral or so it seems. Any ideas? I do have the MLPS switch adjusted as per the instruction on this site and they were very helpful. I check the connectios and they seem fine. Thanks in advance.
Rob
Old Jan 18, 2009 | 07:41 PM
jk080's Avatar
jk080
Transmission Rebuilder
Speedo work?
Old Jan 18, 2009 | 08:09 PM
rob rosencrans
Yes the speedo and tach work.
Old Jan 18, 2009 | 09:34 PM
jk080's Avatar
jk080
Did the old transmission shift?
Anyway you can check for codes?
Old Jan 19, 2009 | 06:27 AM
rob rosencrans
Yes the old one shifted but reverted to high pressure because it was slipping and needed to be rebuilt. I am thinking that the shift shaft maybe in the wrong position.
Old Jan 19, 2009 | 09:52 AM
jk080's Avatar
jk080
I would think that if the shift shaft was in wrong then you wouldn't have reverse or neutral.
A scanner with a data stream would be helpful at this point.
If you unplug the trans at the case connector it should start off in 4th, it will set all the codes but at least you will know that it is capable of another gear.
Alabama Mike
29
Mar 3, 2013 05:26 PM
FordBronco88
1978 - 1996 Big Bronco
17
Aug 4, 2009 10:52 AM
DANA SCOTT
Nov 4, 2005 07:00 AM
