84 f250
Old Jan 18, 2009 | 02:59 PM
93blacktruck's Avatar
93blacktruck
84 f250
A friend and I just picked up an 84 F250 2x4 and we were wanting to lower the tuck 3-4 inches all the way around. now for the question can I get a f150 springs and twin i beam will that work or could I get the dream beam setup? the only thing I didnt see a set up for the f250
any input would he helpful
thanks
Old Jan 18, 2009 | 05:00 PM
Franklin2's Avatar
Franklin2
It may be cheaper and easier to rip the whole frontend out and install a different suspension under it. Rearend too. Then you could get away from the 8 lug rims and have a better selection to choose from.
93blacktruck
the reason I am asking we are using the frame/drivetrain for a ratrod that i have going It is a 51 ****** pu truck and i wanted it to sit low
Old Jan 18, 2009 | 08:32 PM
Franklin2's Avatar
Franklin2
You picked the worst possible donor truck to start with. The f250 is a heavy duty pickup and the front twin I beam is about the worst there is to try to lower, and keep a good alignment. The rearend is huge and heavy. The frame is probably too wide for any old vehicle.
84 f250 6.9
17
Jul 31, 2009 05:25 AM
84 f250 6.9
Apr 1, 2009 03:43 PM
royzell
Electrical Systems/Wiring
Jan 28, 2008 10:54 PM
Windsor84
Sep 19, 2005 12:50 PM
PA F150 4X4
Jun 2, 2003 07:01 PM
