I-beam Stud
Old Sep 9, 2005 | 07:48 PM
Windsor84's Avatar
Windsor84
I-beam Stud
Im lifting my 84 f150 4x4 and i have on side done on the front, took the coil spring retaining nut off of one side and saw that the nut below that was gone i had to cut the top of the stud off to get it out of the I-Beam, so i could get the radius arm off, problem is that Ford said the stud stud/bolt into the I-beam is discontinued, and no junkyards have 4wd trucks, i was wondering if anyone knew where i could find one because this is all that is holding me up. Thanks.
Old Sep 9, 2005 | 10:53 PM
mustange70's Avatar
mustange70
Try lmc truck of jc whitney.
Old Sep 10, 2005 | 07:01 AM
toyscout2's Avatar
toyscout2
Besides LMC, you can try NPD at 800-874-7595.
Old Sep 10, 2005 | 03:14 PM
hoxiii's Avatar
hoxiii
Did you try asking for one for a '96 F150 or a '97 F2/350? It seems strange to me that a part that was used 8 years ago has already been discontinued. But it isn't like it's a part that breaks that much, so maybe they have.
Justin
Old Sep 10, 2005 | 07:57 PM
mustange70's Avatar
mustange70
Or even some of the lift manufactures, they might have something.
Old Sep 12, 2005 | 01:57 PM
66MercMan's Avatar
66MercMan
I had the same problem, I had to torch the nut to get it off and screwed the threads. Ford could not get me one so I went to the local bolt supply house. They did not have the right one either, but had a simmilar bolt but the threads did not go far enough down the bolt. I used an old tap and die to finish the threads. The bolt was very hard but if I worked slowly I could continue the threading. Just another suggestion.
Old Sep 12, 2005 | 02:20 PM
IBeam's Avatar
IBeam
Try this address.
http://www.car-part.com/index.htm
This is a nation wide Internet Hot Line for Auto Salvage.
Hope this is within posting guidelines.
Old Sep 19, 2005 | 12:00 PM
broncoxlt86's Avatar
broncoxlt86
windsor84 get an LMCtrucks magazine they have 66 - 96 bronco parts
Old Sep 19, 2005 | 12:50 PM
82F100SWB's Avatar
82F100SWB
Try here:
http://broncograveyard.com/bronco/i-...stud__each.htm
That should be what you need.
tschmitt
13
Jun 19, 2009 07:38 AM
bliss1
15
Nov 22, 2007 03:26 PM
oldhalftons
Mar 6, 2004 07:22 AM
TryMe
Dec 22, 2002 03:47 PM
loudfords
Jul 25, 2002 05:42 AM
