Lockers?
Old Jan 18, 2009 | 11:54 AM
biggen's Avatar
biggen
Exclamation Lockers?
Has any one put lockers or spool in there X's. I hate not having really 4x4 not this 1 wheel in the front and 1 in the back ****? Any suggestions.
Thanks
Old Jan 18, 2009 | 12:04 PM
BobBarry's Avatar
BobBarry
Thanks
In what conditions are you engaging 4wd?
If you are doing a lot of muddy rutted trails and don't need to deal with tight turns, then just install some Detroits front and rear and be done with it.
If you are doing expedition-style travel with lots of turning, then ARB or one of the electric selectable lockers would be best.
If you are just using it for the occasional slippery grass or snowy street, then a good set of tires and a properly-functioning limited-slip will be all you need, as all tires WILL get some power, UNLESS you lose ALL traction with one tire, at which point that tire gets all the power. Usually, both tires at the other end will still have some traction, so the power going to that axle will pull you through until both tires at the opposite end get some bite.
It all depends how you use 4wd.
Old Jan 18, 2009 | 12:28 PM
biggen's Avatar
biggen
Exclamation
I am tired of not having real 4x4 when I need it. I am not going to rockcraw with it. I live in Missouri so I drive it on the hwy and some dirtroads
Old Jan 18, 2009 | 01:05 PM
Stewart_H's Avatar
Stewart_H
I have a Detroit True Trac in my Lightning. It's a geared limited slip diff so no clutches to wear out or slip.
I quickly wore out my OEM limited slip from too many tire warm ups in the water box at the track.
Stewart
Old Jan 19, 2009 | 11:41 AM
scottf4444's Avatar
scottf4444
I have the ARB lockers front and rear. I got them for use in snow and mud and man...what a difference.
I had the Detroit Lockers on my rock crawler Jeep and I wanted the ability to deactivate them on the Ex, so that's why I went with the ARB. I know comparing the Jeep to the Ex is like apples to oranges, but I didn't want the rough popping of the locker on the family truck that we take when we go out to dinner.
Most the time, I just activate the rear unless the terrain gets really bad as it is damn near impossible to stear when the front is engaged. My brother in law has an 05 Ex in Washington where he gets a lot of snow and I recommended for him to just get the rear at first to see if thats provides enough traction, which for his application, I think it will.
Hope this info helps and if you need any other info, let me know!
Old Jan 19, 2009 | 12:29 PM
afreemanmd's Avatar
afreemanmd
I thought I'd heard that lockers in the front were bad ideas because they bind really bad. Is this not the case?
Old Jan 19, 2009 | 12:58 PM
jbarker_bankspower's Avatar
jbarker_bankspower
Lockers in the front are fine if your doing some serious off roading. The down side is that they will make your turning radius larger and the steering heavier. You should NEVER use front and rear lockers on a high traction surface like a paved road. Otherwise your just begging for some serious drive line binding. A rear locker and a front limited are a good choice if your half on and half off road though. It does take a little getting used to driving with a rear auto locker though. Things like coasting through a turn instead of being on power through a turn.
Old Jan 19, 2009 | 01:57 PM
CanadianSmokie's Avatar
CanadianSmokie
Powertrax by Richmond Gear is another option that you could look at.... fits in the existing carrier so gear setup is not necessary and is very well priced.
POWERTRAX® LOCK-RIGHT LOCKER BY RICHMOND
I would agree with the previous poster who said that a limited up front (the TruTrac would be a good choice) would be the way to go as I don't think too many of us will be hitting the boulder fields
Old Jan 19, 2009 | 10:05 PM
1 Excursion camper's Avatar
1 Excursion camper
Also a locker up front is OK because the front axle is disconnected via the hubs, so you can drive on pavement.
Old Jan 20, 2009 | 10:19 PM
howler4x4's Avatar
howler4x4
Old Jan 21, 2009 | 09:41 AM
soutthpaw's Avatar
soutthpaw
the downside to a non-selectable locker in the front is that the front is always locked when unsing 4x4. not a good option in snow and Ice conditions... you need some slipage for snow and ice.. a locker in snow/ice roads forces a loss of traction...
Old Jan 21, 2009 | 06:38 PM
bad booger's Avatar
bad booger
I find the snow and ice offers plenty of "slipage" and don't see a need for any more. btjm
Old Jan 21, 2009 | 08:25 PM
BobBarry's Avatar
BobBarry
I think he means slippage between the front wheels, not slippage between the wheels and the ground. In a turn with a locker, one wheel will necessarily be sliding, while an open-axle on the snow will have a chance of both wheels turning without slipping.
I'd still like to know the exact conditions under which the original poster is getting hung up in 4wd. You said "dirt roads", but are your axles getting crossed-up on the dirt roads so that one wheel is hanging in the air and the wheel diagonal to it is spinning on the surface?
Or is it a loose but relatively-smooth incline where you're just losing all traction?
Different kinds of lockers are better for different situations.
menzfamfour
Sep 6, 2007 08:48 AM
DarkWolf40
Jun 25, 2006 11:38 PM
motobub
Offroad & 4x4
Jan 5, 2003 09:46 PM
TUNA1
May 20, 2002 11:23 AM
brown 4x4
Jul 17, 2001 04:14 PM
