lockers
Old Sep 5, 2007 | 09:17 PM
menzfamfour's Avatar
menzfamfour
lockers
i have a 85 f150 4x4 is it possible to have lockers in front and back
Old Sep 5, 2007 | 09:41 PM
beaners1's Avatar
beaners1
I don't believe the factory ever did it but yes you can. The front one should have a switch to release the locker. Most are operated by air and are for extreme off road use.
Just to clarify what your asking, you are talking about differential locks and not hub locks, correct?
Old Sep 6, 2007 | 08:45 AM
Franklin2's Avatar
Franklin2
My 1980 has factory "limited slip" front and rear. Not the same as a "locker" you switch on and off, but it's all that was available from the factory.
It acts a little wierd in the snow with the front limited slip. I can actually "steer" the rear of the truck back and forth on a snowy road with the steering wheel. And I have to come to a complete stop if I want to turn into a driveway or something like that, off a snow covered road.
Old Sep 6, 2007 | 08:48 AM
greythorn3's Avatar
greythorn3
ya
you can lock both ends of it.. arbs are about 750 a end.. if you install yoruself.. they are air lockers.. or you could use a detroit in the rear its about 500, or like i did on my sterline rear i just welded the open carrier and make it like a spool.. worked great offroad and wasent horrible in town.. but wasent great in the summer on dry pavement turning either.. but it was less then 5 bucks in welding rod..
ray
Mau
Nov 15, 2011 01:37 PM
awq134
2009 - 2014 F150
Nov 16, 2010 08:26 PM
V10man
Offroad & 4x4
Nov 28, 2007 08:51 PM
tarvis_78
Offroad & 4x4
44
Mar 30, 2004 03:07 PM
Jokenring
Dec 30, 2003 04:12 PM
