Locker Installation
Old May 24, 2001 | 10:09 AM
brown 4x4's Avatar
brown 4x4
Locker Installation
Old Jul 17, 2001 | 04:14 PM
BobS
Guest
Posts: n/a
Locker Installation
I have a F150 with the 3.08 Ford rear axle. I want to install a locking diffential and was considering Auburn Gear's Conical unit or the PowerTrax.
Does installing the Auburn Conical require removing the ring and pinion or not? The pictures lead me to believe the ring gear mounts on it. Its my experience that when you remove the ring gear or put it on a diferent carrier the rear end gets noisy. I have paid to several done at various shops and they always worn me that if they install a used ring and pinion it will not be quiet; they were always right.
I read someplace that the PowerTrac does not require the Ring and Pinion to come out. It this true?
I've got a seeping pinion seal. Can I just go ahead and remove the pinion and then reassemble the rear end (using a new crush sleeve and seal) and not have to check the ring and pinion for back lash, etc?
I never set up a rear end but I've built dozens of manual transmissions and engines over the years. I want to change to 3.73 gears later (when I get the money together) but can install the locker now I will do the ring and pinion myself when the time comes to install it.
Bob
'66 7 Litre Convertible, top loader, 3.25 Traction-lock, 427 Sidewinder Intake, 780 Holley, Windage tray, SCJ Exhaust manifolds, H-pipe, MSD, Line-lock, AM/FM/8-Track/CB
'88 F150 XLT Lariat, 302, 5 speed, 3.08
'98 Mustang, 3.8, 5 speed
'99 Ranger, 3.0, 5 speed, 3.73 posi
351slug
Offroad & 4x4
Mar 16, 2013 10:11 PM
Irish816
Offroad & 4x4
17
May 19, 2010 08:08 AM
Offroad & 4x4
Dec 9, 2006 09:03 PM
4x4x4x4
28
Dec 16, 2002 01:54 AM
CustomCab4x4
Feb 3, 2002 02:20 PM
