-.- tranny question
Old Jan 18, 2009 | 11:49 AM
chillmiller's Avatar
chillmiller
-.- tranny question
well i just spent 500 bucks and 39 hours puttin in a new tranny... havent slept yet.....
well anywho i got every thing togeather.... it starts in part and nutral witch means my linkige is hooked up right i did every thing right........
dont move......
why........
Old Jan 18, 2009 | 01:34 PM
chillmiller
ok update.... when i started it up and put it in reverse it clunked then stalled out.... sooo i assume i killed the tranny witch makes me think that the tranny i got was like sitting on the rack for a while
Old Jan 18, 2009 | 04:01 PM
Pablo-UA's Avatar
Pablo-UA
well, are you sure linkage is ajusted correcty? Does truck runs forward? May be you really have bad reverse band and it is bad becouse to change it you need disassembly tranny fully. I remember a time when I draw aero w/o reverse for more then a year
Old Jan 18, 2009 | 04:05 PM
Graygeorge's Avatar
Graygeorge
Did you run the truck with the rear wheels off the ground so the transfluid would thru the transmisson fully?
Old Jan 18, 2009 | 07:46 PM
jk080's Avatar
jk080
Transmission Rebuilder
Are you sure that you had the converter all the way in the trans when it was installed?
Old Jan 19, 2009 | 06:32 AM
chillmiller
linkage was there i didnt do the rear weels off the ground the book did not tell me to do that and yess i made sure the converter was all the way in
Old Jan 19, 2009 | 06:35 AM
chillmiller
jk080 your tag makes me think that you could help me the most ya think i killed it? as it stands right now i came down staires this mornin and it looked like alot of my fluid was all over the floor.....
Old Jan 19, 2009 | 07:03 AM
chillmiller
just lifted the rear and let it run for 20 minutes until it got hot and put it in drive.... nothing ....
i think i bought a bad tranny..... i guess im gonna call the place i got it from they have another in the same truck as mine ( the one i wanted) and get it changed out for the other..... one ( but this time!!!!!!!!!!!! im gonna make them do the work!!!!!)
i can do lift kits and ect.. on most trucks but that trannys a mother... just where the exaust is and all that
Old Jan 19, 2009 | 09:22 AM
jk080's Avatar
jk080
Check the fluid level with the engine off, remember where it is on the stick. Then start the engine and check the fluid level, if it dropped you know the pump is working.
Where did all the fluid come from?
Old Jan 19, 2009 | 09:30 AM
chillmiller
i think over flow....... not sure i looked under neath and it was coming out of the back not the tail just about where the over flow is also was coming from around the dip stick uhhh hose thing but thats because of the funnel i was useing ill uhh try what you said tho
Old Jan 19, 2009 | 10:03 AM
pawpaw's Avatar
pawpaw
dont move......
why........
Is the tranny fluid level right????
Old Jan 19, 2009 | 10:05 AM
chillmiller
mhmm every things right like i said when i went from part to reverse i heard something clunk then the motor shut off ( same thing it did when the first tranny died
Old Jan 19, 2009 | 10:48 AM
jk080's Avatar
jk080
I must have missed the part that the engine died, does it still kill the engine?
Does it die immediately or slowly shut off?
What is the year and model?
Old Jan 19, 2009 | 10:50 AM
chillmiller
no it olny did it once... witch leads me to belive i killed the tranny ( or it was about dead when i got it) a 1991 ford ranger 3.0 (3 bolt starter) xlt super cab 2x4
Old Jan 19, 2009 | 11:49 AM
jk080's Avatar
jk080
If its full of fluid and still no go it will have to come back out.
Do you remember if the input shaft was in the new unit, they can fall out.
Did you replace the converter too? They can strip.
Make sure it holds in park, if it rolls the rear end could be broke. I have had this come into the shop. The customer installed a new unit and it still didnt move, it was a broken pinion shaft. Just a thought.
