1979 Pulling truck
Old Jan 17, 2009 | 10:20 PM
1979FORD400's Avatar
1979FORD400
1979 Pulling truck
Will a F-150 truck be heavy enough to handle all the weight for a puller?
Old Jan 17, 2009 | 10:45 PM
Holiver31's Avatar
Holiver31
i would personally get a 350 and start out big and just add on to that,,cause i dont you are goin to just keep the frame the way it is to pull,,you can get these trucks cheap go find a 350 and build it up
Old Jan 17, 2009 | 11:15 PM
mark a.'s Avatar
mark a.
No, a 1/2 ton won't hold up to pulling a sled.
Old Jan 18, 2009 | 06:07 PM
Dr. Dirt's Avatar
Dr. Dirt
x2....a half ton isn't heavy enough to pull a sled. get an F350.
Old Jan 18, 2009 | 06:17 PM
bartn98's Avatar
bartn98
350's are great if you can find one but you can find 250's pretty easily...id go with no less than a 250, then throw a 460 and a few axle upgrades(such as a front d60) at it and see what happens....
good luck.....
Old Jan 23, 2009 | 11:40 PM
CowboyFromHell's Avatar
CowboyFromHell
go with a 350. if you can't find a 350 buy a 250 and put heavier springs in the rear with air bags. then, like bartn98 said, a d60 front. i would put a sterling or a dana 70 in the rear
Old Jan 27, 2009 | 08:58 PM
RedFordPuller's Avatar
RedFordPuller
Your chances of finding a 70's F-350 4x4 are kinda hard. I pull a 77 F-250 and a 82 F-250, i've never had any front axle problems with the D44 most of the pressure is on the rearend i've been through 5 driveshafts, couple rearend gears and blew the housing between the trans and t-case once. Just keep the 460 wound tight and hope for the best.
Old Jan 27, 2009 | 09:07 PM
cipsmithers's Avatar
cipsmithers
Just a sidebar, but are the frames from an f250 and an f350 the same, If from the same year?
Old Jan 27, 2009 | 09:26 PM
josher66666's Avatar
josher66666
definately start with the biggest truck you can find
Old Jan 28, 2009 | 11:46 AM
mark a.'s Avatar
mark a.
'79 f250 & f350 frames are the same.
Old Jan 28, 2009 | 03:18 PM
bartn98's Avatar
bartn98
what kind of rear axle u runnin in your 77??
the reason i ask is im thinking of replacing the d60 in my 77 highboy with a d70 or sterling....just dont know which is better...any suggestions
Old Jan 28, 2009 | 05:02 PM
RedFordPuller
I'm runnin the D60 with the factory trac-loc and the spider gears seem to be the weak link so i'm gonna go to a spool. I know alot of other guys around are going to the D80 out of late 90's early 2000's Dodge duallys. I've never had a sterling but the aftermarket seems to carry a lot more for dana's.
Old Jan 28, 2009 | 08:57 PM
bartn98's Avatar
bartn98
are you running aftermarket axleshafts...i would think youd break a shaft before the r&p
