need some help
Old Jan 17, 2009 | 10:04 PM
coltonmolloy's Avatar
coltonmolloy
Question need some help
i am restoring a 74 F-100 an the cab mounts are rusted an i was wondering what is tha best way to get them off of the cab with out hurtin it
Old Jan 18, 2009 | 12:33 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Moved from 2011 F100 forum. Welcome and thanks for joining us at FTE!
Old Jan 18, 2009 | 01:19 AM
F250army45d's Avatar
F250army45d
Been some time since I have done cab mounts but any way my first truck was a 1970 F100 300 3 on the tree. Paid a hundred for the truck I was 16 then 800 getting it road worthy. I used an angle grinder to grind away the old mounts worked good for me and cleans the area up.
Old Jan 18, 2009 | 12:41 PM
coltonmolloy
thnkx thay are spot welded an risted in two i traded A 77 1 TOn for a 74 short wide 2weel drive it was in a lot better condition an i ahe a 351 winzer board 40 over with flat top pistens an comp cams with a 7502 cfm carb an intate set it should scream when im done it will have a c6 trans behind it with 411 gears
Old Jan 18, 2009 | 04:47 PM
Dr. Dirt's Avatar
Dr. Dirt
welcome to FTE!
what's a "74 short wide?"
Old Jan 19, 2009 | 12:00 AM
73BlackBeauty's Avatar
73BlackBeauty
What I did for mine was drill out the spot welds. This was a very clean and easy way of doing it. Then take the time to clean up the area and prevent it from rusting again.
Old Jan 19, 2009 | 06:07 AM
bucks77ford's Avatar
bucks77ford
I also drilled out the spot welds. There are quite a few and takes some time, but if done right the new cab mount plops on and weld where the spots were. I would recommend getting the drill bits made for drilling out spot welds. They work really nice.
JnastyG
Sep 3, 2010 01:55 AM
Mark223
Jan 18, 2010 10:46 AM
JCastellaw
1966 - 1977 Early Broncos
16
Sep 22, 2006 08:57 PM
pickups
Dec 31, 2004 06:30 AM
