Small problem?
Old Jan 17, 2009 | 05:26 PM
liv's Avatar
liv
Small problem?
So I lost reverse the other day.
Put her up in the air.
And found this...
Turns out the caliper pins had dried up. Other pad was barely used. Didn't hear/feal a thing. The only downside of having a 4" turbo back on an 03
So I went ahead and did this. Replaced all 4 rotors due to the fronts being somewhat warped. Then put some Billstein 5100's on
All better
Also some pictures of my new headunit
Old Jan 17, 2009 | 05:35 PM
04F-250mark's Avatar
04F-250mark
Don't mean to highjack . Sorry about the bad luck on the brakes I noticed you had a B&W hidden goose neck . Mine has one in the bed it recested in the bed ,just wandering how to get it to come up I've tried to get it out don't know how it comes up.
Old Jan 17, 2009 | 05:44 PM
liv's Avatar
liv
On the drivers side over the rear wheel there's a pin that you pull and twist. If you've never had it out before yours going to have to take a torch to it They get stuck pretty easily. You can also try releasing the pin then jacking up the trailer with it still attached. That works sometimes.
Old Jan 17, 2009 | 05:47 PM
04F-250mark
Thanks I'll try it in the morning
4tl8ford
1692
Mar 5, 2026 05:58 PM
93f1505.0L
Dec 31, 2008 06:55 AM
spazinweasel
Apr 15, 2008 04:44 PM
spazinweasel
Apr 13, 2008 10:26 AM
