Another Newbie Question
Old Jan 17, 2009 | 01:41 PM
kissingbug1978's Avatar
kissingbug1978
I'm new to the PSD or any diesel for that matter. I just bought a 2004 F250 CrewCab 4x4 with 84,000 miles on it. Already has 4" exhuast and the converter is gone. Question is about the EGR. Where is it. How hard is it to delete and how does it effect emissions testing. And will this help with the head gasket demon that seems to haunt these trucks. Trying to elimnate problems before they occur. Thanks
Old Jan 17, 2009 | 02:48 PM
dcaddi2's Avatar
dcaddi2
Do your research on this forum, there are several threads about EGR, Egr cooler issues, delete.
The EGR cooler failure could be one of the issue, what blows the HG, but just because you delete it, doesn't mean you won't have HG problems. Most commonly the high boost lifts the heads because of the weak, stretchy head bolts.
Old Jan 17, 2009 | 03:06 PM
toolman05kr's Avatar
toolman05kr
I agree completley. sticking turbo veins and overboosting is definatley the #1 cause of HG failure.
Old Jan 17, 2009 | 08:22 PM
kissingbug1978
high boost meaning tuned engines?
Old Jan 17, 2009 | 08:44 PM
bismic's Avatar
bismic
The 6.0L uses a Variable Geometry Turbo. This means that the turbo has vanes that adjust to give you more or less boost as your computer deems appropriate. When the vanes stick, you can overboost whether you are tuned or not.
