test temperature sensor?
Old Jan 17, 2009 | 12:49 AM
Chuck14's Avatar
Chuck14
I have an 84 F150 with a 351W. When I start it up, the temperature gauge always goes up to the high end of the normal range (but not past it) within a couple of minutes, even when it's pretty cold outside. I don't think the engine is really that hot because the heater doesn't start blowing hot for a few minutes after that. I have never seen it go past the high end of the normal range and the engine has never given any indication of overheating.
Is there anyway to test the temperature sender to see if it's fried, maybe check its resistance or something? Or maybe it just needs to be adjusted? Where would you measure the engine temperature with a meat thermometer to see how hot it really is?
Old Jan 17, 2009 | 03:30 PM
Conanski's Avatar
Conanski
Yep.. Ford Fuel Injection has some info on testing sensors. You could have air in the motor as well, when was the coolant level last checked?
Old Jan 28, 2009 | 11:47 PM
Chuck14's Avatar
Chuck14
How/where do you check the coolant level? There is nothing in the overflow container (front half of the plastic thing that also holds windshield washer fluid).
Old Jan 29, 2009 | 08:18 AM
Conanski's Avatar
Conanski
Remove the rad cap and look inside(cold engine), it should be right at the top. If it isn't top it up and fill the overflow container to the cold fill line.
Old Jan 29, 2009 | 10:42 AM
Chuck14's Avatar
Chuck14
The radiator was a bit low. I added about a quart to it this morning. I don't see any cold fill line on the overflow bottle, so I put about 2 inches of antifreeze in the bottom of it.
Once the engine heats up, the temp gage is still reading pretty high. Not pegged, but just to the right of the "L" in NORMAL. You mentioned the possibility of air in the engine before. How would I check for that and correct it?
Old Jan 29, 2009 | 11:24 AM
MBDiagMan's Avatar
MBDiagMan
Here's a quick way to get an idea if the problem is gauge and associated circuitry or sensor. Disconnect the wire from the sensor and ground it. This should cause full deflection on the gauge. Then leave the wire disconnected from the sensor and with it disconnected and the key on, you should get zero deflection from the gauge.
If the gauge acts properly under those conditions, replace the sensor. If there is something wrong with the gauge and circuit, in your case, then you will have gauge deflection with key on and sensor wire disconnected.
Joey92
Jan 4, 2011 04:21 PM
eyyu
15
Nov 10, 2007 09:14 AM
ernesteugene
46
Jun 28, 2007 11:21 PM
ocean_461
Jul 28, 2003 09:47 AM
