Big 3 upgrade 2000 V10
I just picked up a new 160 amp alternator to replace my OEM unit. I plan to do the big 3 upgrade by running new parallel (4 ga) lines. The new positive alternator to battery line is simple enough, but I have a question regarding the negative battery to block and block to chassis lines.
Specifically, do you need to use the same connecting points as the stock locations? I found the stock braided wire that runs from the top of the firewall to somewhere near the top back of the motor (it was dark and I couldn't see where it terminated) and I think I found where the stock ground cable runs from the negative battery post to the frame rail and then, I presume, onto somewhere on the block - I think near the front, bottom part of the motor. Both ground locations on the motor seem tough to get to so I was wondering if there are other connecting points that will work.
Any help would be appreciated.
Thanks,
Brian
Now, that Ive got all that off my chest, can I ask why you think you need to do all that? The only thing I did to the factory system was put a nice piece of 4 ga, between the battery, and alternator, to replace the #6ish fusable link, to help with voltage drop. Now my secondary, rear battery system, I added a second alternator, and have two large batteries (105 AH each IIRC) and some 2 ga wire between the batts, and alternator, and a few shunts for monitoring, to run my inverter and 12v accessories. The only thing on the factory side of things, Id change, (and did) was the wire between the alternator and batteries.
EDIT: Sorry if any of that seems upfront, or mean. Its not intended to be mean, just hate to see good wiring go bad, and cause problems. Also starting a small block gasser motor, with 9:1 compression takes a lot less power to turn over then a 444 cubic inch diesel with 18:1 compression ratio. While I realize you have a gasser, its also a 415 cubic inch V-10
Brian
