Diesel Jelly
Old Jan 16, 2009 | 04:10 PM
Lou Braun's Avatar
Lou Braun
Diesel Jelly
It looks like several of us are seeing cold weather related diesel fuel problems.
This morning it was -15 degrees F. The truck started fine and ran well for about a mile then it started loosing power. Classic diesel jelling symptoms.
A photo of the HFCM filter is attached.
Lesson learned. It is easier to add an anti-gel additive to the tank than to drain the HFCM and change out the filter while lying in the snow when it is below zero outside.....
Lou Braun
Old Jan 16, 2009 | 04:20 PM
UGA33's Avatar
UGA33
looks yummy! I bet that was the worst filter change to date for ya. This morning in N. Ga the temps in my neck of the woods hit high single digits and my buddies D/Max did the same thing.
Old Jan 16, 2009 | 06:35 PM
bismic's Avatar
bismic
Thanks for posting the picture - it really does speak for itself!
Old Jan 16, 2009 | 06:46 PM
Lou Braun's Avatar
Lou Braun
I wish someone had taken photos of the "under the truck in the snow" part of this project!
Temperatures are projected to be -15 degrees again tonight. We will see if all of that Power Service and 911 stuff that I added works tomorrow.
Lou Braun
PS: I took that jelly-covered filter and tried to get the jelly to melt. It did not. It looks as if once the wax component of diesel fuel settles out it will not readily go back into solution. I'll bet that the Alaska folk know all about this.
Old Jan 17, 2009 | 02:32 AM
duallyking's Avatar
duallyking
My truck was running weird. Didn't want to go to WOT and didn't want to go into overdrive.
I'll check my filters. Does the wax settle in the fuel tank too?
Old Jan 17, 2009 | 03:55 AM
Frankenbiker's Avatar
Frankenbiker
Diesel fuel has two components; an aromatic component, and a paraffinic component. What clogs the filters is the paraffinic component. The aromatic fraction is similar to gasoline.
Once it's OUT of solution, it's just like the paraffin that your grandmother used to seal jars of homemade jelly. It takes 100+ degree heat to get it to melt.
If it's still immersed in diesel, it'll melt at just over freezing (32 deg), thanks to the aromatic fraction of the fuel. If you have some of it left, drop it in room-temperature gasoline and watch it melt. It won't melt quickly, but it will melt.
Ya'll may have heard of stories of unfortunate truckers who had their entire tanks freeze up. This unfortunate situation requires the truck to sit in a heated shed/garage for as many as 3-4 days before the entire fuel supply (some 200+ gallons) completely liquefies.
(And for the record, PowerService White seems to peform FAR better at keeping fuel liquid than does Howe's, although I'm not to day 3 on the P-S, where Howe's had one tank partially frozen after 3 days of sub-zero temps last year.)
-blaine
Old Jan 17, 2009 | 03:58 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Amen to that. I like to double dose when temps get this low, I couldn't imagine trying to change out the FF on a day like we've had here the last 2-3 days (-5ish with wind chill) Those pics make me want to go out and dump some more PS in my truck Thanks for the pics!
seattle smitty
Dec 22, 2014 10:32 PM
Ford E350 Ambulance
Nov 9, 2014 08:17 PM
Chris Braun
Sep 3, 2014 08:38 AM
mx250racer1
6.4L Power Stroke Diesel
Mar 26, 2014 11:16 AM
Chris Braun
Mar 17, 2013 12:28 PM
