Did My manifold Gaskets
Started it at 7 am this morning. No studs broke I sprayed every stud last night Let it sit over night. Drove 6-miles to my bosses shop this morning (Heated its 3 deg's outside) SO i spray everything again... Start working on it..Left side (drivers) Pull the old ones out put new ones in. Change oil all done by 10:45. Go to start it... Leaking worse this time..So i shut the motor off really quick. So i look at it again. take it back apart and i seen the frt gasket was pinched so i changed it again. Frt two nuts and studs took an hr to do.. Any how put it all back together for the 2'nd time and it still leakes but not as bad... Re tightened everything while motor was running. Better But i think my manifold is warped So i'm going to order one and do it again. But all in all it wasen't a bad job. Need some other thoughts.
MArk
MArk
is doubling up the gaskets a no-no?? just a thought, something to try. you'd be able to tighten the nuts tighter, (so to speak) and with more material there to compress, it might work...
i think FTE ken posted some headers that had 3/8ths flanges on them. they looked real sharp and being milled like that might not warp so bad??
MArk
MArk
I sincerely wish you the best of luck with your endeavour. I too was amazed with how long it took them to replace them at a shop.
FTE Ken just installed some Dynatech headers with thick thick flanges. You are already in there, maybe some shorty headers or new manifolds are in order since it seems your stockers are bent
I'll bet that trailer is the reason why. I know a guy on another forum who is on his 4th or 5th set of manifolds by now. but he spends alot of time playing on the dunes
didn't know you got a new truck...liking it?
Yes i do have a body lift Witch i do think made a difference. I was able to take the tire off and it was right there. The bottom frt to bolts were very hard to do. almost an hr to do just them. I'm going to look into something. Going back to my body lift. When buying it i was skeptical. but it looks nothing like the old body lifts. It was a good move on my part. I'll let you all know the out come.
Mark
Mark
you gonna pick up some OEM manifolds...probably would be the easiest and cheapest fix
glad they did you right...and as much as it pains me to say it ...I told you so about that trade-in part
DSMMH
12-20-2018 04:13 PM
webslinger67
10-14-2013 03:47 PM
DrainBramage
19
08-30-2011 12:20 PM
