Local 400 build,
Old Jan 15, 2009 | 02:04 PM
GONZO86's Avatar
GONZO86
Local 400 build,
A guy in the local paper is trying to sell a 400m with 7300 miles on it
he claims it 450 hp
here is what he says it has
its bored 40 over, keith black pistons,rings rods and bearings. stailess scat crank, aluminum rockers, high flow oil pump, heads are ported, with double rate springs, comp cam, 70 gpm water pump, chrome ford valve covers, chrome oil pan, 750 double pumper holley carb, msd everything,
What is a fair price to pay for this as it is sitting on a stand and no way to hear it run or to tear it down to conferm parts.
What is a Guess on what the true Hp/trq would be
thanks
Rodney
Old Jan 15, 2009 | 06:37 PM
hollenjoe's Avatar
hollenjoe
if i were you id demand a head to be pulled of to see the condition pof the cylinder and what pistons you have, if what he sayas is right, you have good pieces there. Ask what kind of heads the engine has, cuz 2v open chambered heads are very delicate and have water pasages near the ports making them nearly imposible to port, also 450 hp with the 2v heads is quite hard-impossible.... ask also what cam was used in the build
Old Jan 15, 2009 | 06:43 PM
hollenjoe's Avatar
hollenjoe
take pictures y if you can, post them here so we can help you further and whats the going price?
Old Jan 15, 2009 | 07:24 PM
Mud Rat's Avatar
Mud Rat
A couple of comments:
1) 450 HP? Look at TMI's dyno tests. I doubt it.
2) I port 351 C 2V heads. You can reduce restrictions, but you can't make them racing heads.
3) Don't buy one, build one
Old Jan 15, 2009 | 10:01 PM
GONZO86's Avatar
GONZO86
price
The guy is only asking $1200.
I will swing by to check it out on SAT
Old Jan 16, 2009 | 08:32 PM
mark a.'s Avatar
mark a.
I've never heard of a stainless steel crank shaft.
Old Jan 16, 2009 | 08:51 PM
hollenjoe's Avatar
hollenjoe
yeah i have, an australian guy who posted around here said he used a eagle steal crank, so it could be true....
Old Jan 17, 2009 | 08:23 PM
mark a.'s Avatar
mark a.
I don't believe the hp rating, but it might be a good motor. Maby have him put it in and get it running then if it seems ok pay him.
Old Jan 17, 2009 | 08:38 PM
danlee's Avatar
danlee
SCAT and Eagle make steel cranks for 351W motors. With the right timing set, these cranks can be used in a 351M/400 block.
To get 450 HP, you need lots of compression or lots of cam. If it's a low compression motor with a big cam, don't buy it.
How does he know it makes 450HP?
Was it Dyno'ed?
If so get the Dyno numbers. See what the RPM is where it makes 450 HP, and what the torque is at the lower RPMs.
What Intake Manifold does it have?
How does it get the compression to get 450 HP? Aussie heads?
Flat Top zero deck height pistons?
Old Jan 18, 2009 | 02:10 AM
GONZO86's Avatar
GONZO86
Swung By
Well I swung out today and took a look,
Looked clean, edel performer intake, holly on it and had a demon 725 fot it as well
Had a box of other stuff for it, all the Msd stuff , powermaster alt
New 4 core radiator with elec fan
Told the guy it would be a core since I had no way to verify internals or to hear it, or play with it.
But it did have crome ford valve covers, that were cherry
Offered $600
d7te a2b 7l10
Its on the stand in the garage now, Old lady is pissed.........
Old Jan 18, 2009 | 02:37 AM
hollenjoe's Avatar
hollenjoe
well, errr all ouve menioned, for me its worth...
Countryboy81
Aug 28, 2013 10:53 AM
joel79ford
Mar 25, 2012 11:21 PM
cruz76
May 21, 2007 12:08 PM
dimora
15
May 21, 2004 06:09 PM
mustange70
May 9, 2002 06:31 PM
