rediculous!
Old Jan 16, 2009 | 01:49 PM
  #31
plowhand's Avatar
plowhand
Playing in the Dirt
Great, I'll add it to my list of parts.
Old Jan 16, 2009 | 03:11 PM
  #32
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Originally Posted by c00nhunterjoe
they dont list one for the 99 up trucks and the part directory only shows it fitting our years
Well the number 699-200 is for our trucks and the number 699-201 is for 99 an up:
https://www.dormanproducts.com/cgi-b...tegory_list=:0
Old Jan 16, 2009 | 04:33 PM
  #33
BlueMule's Avatar
BlueMule
Originally Posted by 2 stroke man
i know its bad. so just where for sure is the TPS? they said TPS was under the hood, and there was an accelerator position sensor on that assembly and it would cost $350 for the assembly
Here's a picture that shows both the TPS and IVS. The bigger switch at the top of the pedal with the 2 torx screws is the Throttle position switch and the little one with the red boot on the plunger is the Idle Validation Switch.
Several years ago Ford told me the switch was not available seperately and the whole assembly was $130.00
I bought what was supposed to be a 97 pedal assembly off ebay and the seller sent me a 2000 pedal assembly by mistake.
The TPS's on both pedals are exactly the same and even have the same part numbers molded into the plastic. I don't know if all the 7.3 SD's use the same switch but for sure at least the 2000 and 96 are interchangable.
Old Jan 16, 2009 | 04:39 PM
  #34
2 stroke man's Avatar
2 stroke man
ok guys, THANKS!!!! c00n, i cant give you green beans. think it could be from my chip if i have a bad connection? i dont personally think so. but eh. they said the TPS was under the hood? is there some sort of throttle sensor under the hood?
Old Jan 16, 2009 | 05:10 PM
  #35
BlueMule's Avatar
BlueMule
No........
Old Jan 16, 2009 | 06:59 PM
  #36
ono_55's Avatar
ono_55
Originally Posted by don77
lol muffler bearing hell they may believe it and look for it
The older Pets had a muffler bearings
Old Jan 16, 2009 | 07:26 PM
  #37
tjbeggs's Avatar
tjbeggs
The E4OD IDI's had a TPS under the hood but not the PSD. Someone needs to get that Dorman TPS and try it. I have heard its junk or doesn't fit right.
Old Jan 16, 2009 | 07:38 PM
  #38
pjwoolw's Avatar
pjwoolw
Don't forget to have them check the henway.
Old Jan 16, 2009 | 08:46 PM
  #39
kawa's Avatar
kawa
Your just dieing for someone to ask the fatal question huh?
Rog
Old Jan 16, 2009 | 10:10 PM
  #40
2 stroke man
thanks again guys. think its worth trying the dorman?
Old Jan 16, 2009 | 10:18 PM
  #41
joe_13894's Avatar
joe_13894
Don't leave the dealership without them setting the dwell and gap, and don't forget your halogen fluid.
Old Jan 16, 2009 | 11:21 PM
  #42
don77's Avatar
don77
lol this ford dealer bash is still going men
Old Jan 17, 2009 | 12:41 AM
  #43
JethroF250's Avatar
JethroF250
i'd like to know what they are smokin and where can i get some. that must be some good stuff lol. i tooke the stock rod out and put a 1/4" all thread in so i can get the true full throttle. i accidently bent my assembly so the TPS was stickin and truck wouldnt run. Ford said i need a 300 dollar assembly so i said give me a wrench and some pliers and i'll bend it back myself. it works fine now. that just goes to show the real meaning of "Stealership"
Old Jan 17, 2009 | 02:35 PM
  #44
2 stroke man
think i should just go get a dorman and stick it in there?
Old Jan 17, 2009 | 09:43 PM
  #45
oldbird1965's Avatar
oldbird1965
Originally Posted by kawa
And by all means don't forget the "Cadillac Battery Water"
Rog
Do you mean "Cadillac Battery Water" in a gel battery?
