Modular V10 (6.8l)
Towing power
Old Jan 15, 2009 | 05:51 AM
MSD's Avatar
MSD
Towing power
I have a 2001 V10 supercab with 3.73 gears. I tow a 35' fifth wheel camper that weighs about 11,000 lbs. I can get between 7 and 8 mpg if I don't push the motor going up hills. I don't go below 50 mph on a hill. If I push it to the speed limit mileage drops to about 5 mpg.
Is there anything I can do to increase my towing power so I can maintain the speed limit and get 7 or more mpg?
Old Jan 15, 2009 | 07:25 AM
swann79's Avatar
swann79
Regear. 4.30 gears will give you more power AND slightly increase your MPG when towing. Your engine is overworked pulling that much weight with those tall gears. 3.73s aren't even an option anymore with the V10, I don't know why they ever used them in the first place.
I too tow an 11,000 lb camper with 3.73s in a 2001. I hope to upgrade the gears soon myself.
Old Jan 16, 2009 | 05:00 AM
MSD's Avatar
MSD
Thanks. I thought I would have to swap gears.
Since I only tow a few times a year, would 4.11s be a better choice or would they still be too tall?
Old Jan 16, 2009 | 05:24 AM
rich250's Avatar
rich250
absolutely do the 4:30's,I swapped from 3:73's to 4:30's last summer and I wish I would have gone with 4;56's and my camper is not as heavy as yours.
besides a gear swap you could ditch the restrictive ypipe and get a sct tuner,can't say your gonna gain any fuel milage but should help pulling power.
Old Jan 16, 2009 | 05:50 AM
MSD's Avatar
MSD
Ok I'm convinced, 4.30s it is.
Another quick question. I have to do both front and rear differentials, right.
Old Jan 16, 2009 | 06:53 AM
scraprat's Avatar
scraprat
Top Answer: 5
Yes, you will have to do both.
Old Jan 16, 2009 | 09:36 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Gears are the one thing that produce an increase in torque-to-the-ground across all RPMs, and all speeds.
Going from 3.73 to 4.30 is a 15% increase in torque-to-the-ground.
Old Jan 17, 2009 | 09:07 PM
balfor's Avatar
balfor
definitely do the y-pipe. For around $200 or less installed you can't go wrong. I tow 10k and it helped. I do have gears though as well (4.56's)
22rimfire
6.2L V8
Aug 20, 2013 08:53 AM
sdetweil
Nov 4, 2009 07:48 PM
ford_07
2009 - 2014 F150
Nov 2, 2009 06:09 PM
carltonmason
May 7, 2007 11:25 PM
wbones9
2004 - 2008 F150
Sep 19, 2006 09:02 PM
