Vibration on acceleration
Old Jan 19, 2009 | 04:57 PM
EMD_DRIVER's Avatar
EMD_DRIVER
After two trips to NAPA and one delivery from NAPA, I got all the parts I needed. I had to drive 30 miles to get the right carrier bearing, since they gave me the wrong one on Saturday. I also found one bad u-joint and they gave me the wrong one of those too! All of this running I did today, was due to one salesman.. Afterwards, I was told not to trust this guy.
Anyway, I went to the locomotive shop to get the bearings swapped. We used the 45 ton press to get the old one off. I'm glad we used the press!! It took a lot of pressure to get the old one to come off the drive shaft. When it finally broke loose, there was a pretty loud BANG
The u-joint I had to replace was the one nearest the carrier bearing. I'm not sure which one went bad first, but I'm pretty sure they helped each other wear out. The u-joints for my 93's drive shaft are NAPA 331. I was very pleased to see MADE IN USA on them
I asked them about straps, for the axle yolk and was told that they have a kit with two straps and four bolts. The number on the kit is: 331-10 and comes with hex-head bolts!
I was also able to re-use the keystone clamps, on the slip yolk boot. I don't have a crimper, but it was easy! I got everything back together and brought the drive shaft home. It was then that I discovered that the strap kit I had gotten, was missing a bolt! My last trip to NAPA got me one that was complete.
I got the drive shaft back in the truck and I am giving the blue loctite a chance to dry a bit, before I take it anywhere.
powerstroker100
Sep 13, 2017 07:21 PM
Hailguy1
Feb 10, 2017 09:29 PM
Chris Karsseboom
Feb 21, 2016 09:26 PM
Thor80
May 21, 2014 08:37 AM
drtyhatch
May 26, 2012 04:15 PM
