push rod length
Old Jan 14, 2009 | 06:35 PM
F-250 restorer's Avatar
F-250 restorer
push rod length
I pulled a 78 300 from the bone yard. I may be jumping the gun a bit, but I have the H519P30 pistons going in, and I am going to have the shop bump the compression up to 8.9:1.
I don't want to use the bone yard push rods because I'm not sure of the milage, etc. However, when I shop around I notice there are three different lengths available. Should I let the shop order the push rods? Sizes vary about 1/10". That seems quite a bit to me.
Learning...
Old Jan 14, 2009 | 07:05 PM
Harte3's Avatar
Harte3
Good idea...let the shop do it.
BTW, what did they say about the rocker stud size?
Old Jan 14, 2009 | 08:51 PM
F-250 restorer
Harte3, you were right about the rocker stud size. When I checked the stock rockers fit on the new studs.
I'm dying to hear it run!
Old Jan 14, 2009 | 09:59 PM
Harte3's Avatar
Harte3
I am sure you are!
Old Jan 15, 2009 | 04:29 PM
slammercb's Avatar
slammercb
If you haven't got the means to do a valve train geometry check then let the shop do it as they have the equipment.
Chuck
Swatter
Sep 17, 2009 05:10 PM
reifwj
Apr 24, 2008 06:47 PM
ibleedfordblue
Apr 4, 2007 03:31 PM
ssap108
Aug 25, 2003 12:25 AM
fatfenders
31
Jan 26, 2003 04:45 PM
