460 push rod length
Old Aug 21, 2003 | 12:13 AM
ssap108's Avatar
ssap108
Question 460 push rod length
I had to do a valve job on my 1990 f350 460,(took heads to machine shop) does this usually affect valve clearance if they do the heads right? my truck has hyd. lifters- no adjustment - have to replace push rods. ive never done a non adjustable vehicle before thank for your help.
Old Aug 21, 2003 | 12:25 AM
c_rossman's Avatar
c_rossman
460 push rod length
If you dont take more than .01 off I wouldnt worry about it, I would however check the valve clearance with a bleed down tool, It should be between .1 and .2 of an inch on the valve side
Old Aug 22, 2003 | 06:23 AM
ludis's Avatar
ludis
460 push rod length
I had a valve job done on an engine (other than a 460). The shop ground the seats - and then ground a bit off the tips of the valves. This kept the rocker geometry the same.
Old Aug 23, 2003 | 12:50 AM
ssap108's Avatar
ssap108
460 push rod length
i got my heads back yesterday and the machinist said it shouldnt be a problem either,but i think i'll check clearances anyway just for peace of mind. thank you guys for the input.
Old Aug 24, 2003 | 11:00 PM
Brian460's Avatar
Brian460
460 push rod length
What is the stock pushrod length? Also is it the same for all 429/460's?
Old Aug 25, 2003 | 12:25 AM
ssap108's Avatar
ssap108
460 push rod length
i dont know what the overall length is but my ford book says they have a pushrod .060 shorter and a pushrod .060 longer if you need to adjust valve clearance.
thatguy71
Sep 7, 2016 06:17 PM
william16339
May 27, 2016 06:53 PM
gordo2
22
Jul 6, 2011 11:47 AM
tater_51
Dec 31, 2010 06:45 AM
68murc
Nov 11, 2008 07:42 AM
