Plug in or not?
Old Jan 14, 2009 | 12:43 PM
hittingguru's Avatar
hittingguru
Plug in or not?
This is my first winter with this truck- 05 f350 with the 6.0 turbodiesel. At what temperature should I start plugging in the truck, and how can I tell if the block heater is working?
Old Jan 14, 2009 | 02:11 PM
UGA33's Avatar
UGA33
Everyone's plug-in temp is different. I live in N. Ga and my magic number is 15*. Only had to plug it in a couple of times this year. You can tell because the motor gets up to temp much faster and the cab heat comes on quicker. It all depends on if your truck does good or bad on below freezing starts. Mine does fine so i let it get to 15*. Just my preference
Old Jan 14, 2009 | 02:13 PM
powerstroke72's Avatar
powerstroke72
I usually use mine below 20 degrees F. When I plug it in, I can hear a real light buzzing noise under the truck. Makes a world of difference IMO. Heater warms up a lot quicker and engine starts easier.
Old Jan 14, 2009 | 02:32 PM
Sarge261's Avatar
Sarge261
Right around 20* for me. My truck is lucky usually its kept in a heated garage. But for the times its not I do keep it plugged in. Some people put there truck on a timer I dont. I just plug it in before I go to bed and unplug it when I get up and go to work. I do that cause I may get a fire call in the middle of the night and the truck is warm and ready to go...plus the heat comes up quick and with a crew cab there is a lot to heat up so every little bit helps. As you drive and get used to your truck you will know at what temp you should plug it in at.
Sarge
Old Jan 14, 2009 | 02:44 PM
BLK94F150's Avatar
BLK94F150
How cold does it get where you live? You'll have to come up with a temp yourself, as this engine should start in pretty cold temps by itself.
You'll be able to tell if the block heater is working by how it sounds when you start it. If it's below freezing for a couple of days, let it sit out side w/o being plugged in. It will sound aweful when you start it. Then plug it in overnight and start it. It will sound much better if the heater is on.
Mike
Old Jan 14, 2009 | 03:37 PM
hittingguru
Thanks- I've been plugging it in since it dropped below 25 here in North Central PA, and last night, tonight, and tomorrow night it has been and will be below 0. I noticed that with the recent snow, there was no snow on the hood, but the grill and headlights are covered in ice. I figured the block was heating and then the runoff was refreezing on the front of the truck.
Start up is pretty much the same as warm weather, so I guess everything is working well.
Old Jan 14, 2009 | 07:28 PM
bloodline666's Avatar
bloodline666
ive heard that plugging it in spins the meater on your house. anyone notice a higher electric bill from this or know if thats true. i put mine on a timer but just curious and maybe other people are as well thanks.
Old Jan 14, 2009 | 07:48 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Brrrr
Up here it has been about -8 lately. We plug in normally and run a light weight oil 10W30. I use a timer which turns on about 3 hrs before needing to start the trucks. For every 24 hr period (I just figured it out on another forum) it will cost around $3.60 in electric bill. (.15 per hr)
Old Jan 14, 2009 | 08:50 PM
POWERSTROKER07's Avatar
POWERSTROKER07
i plug mine in when it gets below 20*..i have a outdoor digital timer that i use.i set it like 3hours before i go to work fires right up
Old Jan 14, 2009 | 08:54 PM
liv's Avatar
liv
What kind of oil are you using that you can get in 10w30?
Old Jan 15, 2009 | 07:06 AM
ponyboy123's Avatar
ponyboy123
I only plug my truck in when it drops below -15 deg. It starts fine in cold temps but when it gets real cold the exta heat in the engine really helps. Also helps heat the cab a little quicker.
Old Jan 15, 2009 | 07:33 AM
ljutic ss's Avatar
ljutic ss
When your electric bill comes in, see what they charge you per KW and and multiply that by the number of hours you are plugged in. The heater is 1 KW
my rate is 13.6 cents per KW.
Old Jan 15, 2009 | 10:14 AM
bigredtruckmi
Veteran: Navy
Purchase mine at the local IH dealership and it is from IH. Rated for diesel engines.
Old Jan 15, 2009 | 12:16 PM
flashart24's Avatar
flashart24
How come my 07' does not have a place to plug in? I have noticed that at different temps my RPMs will very after cranking my truck int the morning.Seems like it knows when it is cold out.25* here.
Old Jan 15, 2009 | 02:48 PM
mnmwhit's Avatar
mnmwhit
I plug in at -20'F the synthetic oil helps
