Plug in or not?
Old Jan 15, 2009 | 06:08 PM
liv's Avatar
liv
Originally Posted by flashart24
How come my 07' does not have a place to plug in? I have noticed that at different temps my RPMs will very after cranking my truck int the morning.Seems like it knows when it is cold out.25* here.
The block heater plug was an optional extra though they did come equipped on every truck being shipped to the northern states. All 6.0's have a block heater you just have to go and buy the plug. There's a write up on installing the plug in the tech folder I believe.
The RPM jump is accelerated warm up, and you are correct. The computer tells itself that its cold out and boost up the rev's.
Old Jan 15, 2009 | 06:16 PM
ponyboy123's Avatar
ponyboy123
I know one thing, my truck is plugged in tonite. Callin for -30* and it -28* already. Wouldn't suprise me if it gets lower.
Old Jan 15, 2009 | 06:37 PM
sandmanf250's Avatar
sandmanf250
kendall makes a cj-4 rated 10w 30 diesel oil
Old Jan 15, 2009 | 07:44 PM
brooklyn born's Avatar
brooklyn born
tonite will be the first time this truck has been plugged in. thats because ford finally got the block plugs that were on back order. it is now hooked to a timer to kick in 1 1/2 hour before i leave for work -25deg tonite. lets see if it helps. actually started fine this morn. at -19deg.
Old Jan 15, 2009 | 07:57 PM
slowmans's Avatar
slowmans
I believe rotella makes a 10w-30 but dont quote me, you'd be really happy with a 5-40 synthetic!!!!
Old Jan 15, 2009 | 08:30 PM
conger's Avatar
conger
Originally Posted by hittingguru
This is my first winter with this truck- 05 f350 with the 6.0 turbodiesel. At what temperature should I start plugging in the truck, and how can I tell if the block heater is working?
I plug mine in below -15C. I leave it plugged when I'm warming it up. Usually about 10 min. I just changed my thermostat last sunday since it wasn't waming up much and below -20C it wasn't warming up at all. Big difference, much better now. You can usually hear a bit of a sizzleing noise about 20 sec after plugging in a cold engine. Short warm up times are beginning to be an issue where I live. Our city is proposing an anti-idling bylaw and it looks like it will pass. They'll give you 3 minutes to warm up your vehicle unless the temp is below -10C. The fine is supposed to be $250
If you go to 10w30 for diesels, you'll save you self some injector headaches down the road. The 6.0's don't like the 15w40 in the winter.
Old Jan 16, 2009 | 12:33 AM
BMWM1's Avatar
BMWM1
I dont know but I just brought my truck in from outside and it didnt want to start up it finally did but ran awful.Its about 12F here now they say around 4F for a low tonight.I would think pluging her in would only do good things.There has to be less wear and tear on a engine when you start it warm
Old Jan 16, 2009 | 10:51 AM
stuartmcnair's Avatar
stuartmcnair
I live in Alabama and hate cold weather. I plug mine in more for having the heat come on quickly than for starting it. If it gets down to 35 at night I have it plugged in. I could care less about the power bill - I want heat!
abranz
13
Sep 13, 2016 10:28 AM
mxracer3276
25
Jan 10, 2009 10:09 AM
jwtimme
Apr 10, 2008 01:27 AM
mark31019
1997 - 2003 F150
16
Jun 8, 2007 11:25 AM
frdmike
Modular V8 (4.6L, 5.4L)
Jan 22, 2006 04:02 PM
