Drl bypass plug
Old Oct 28, 2014 | 10:04 PM
abranz's Avatar
abranz
Drl bypass plug
I realize trucks without drls have a bypass plug. I'm trying to disable my drls but don't have a jumper plug. Which wires does the plug make continuity with on a 93 f150? Thanks
Old Oct 29, 2014 | 03:23 PM
abranz's Avatar
abranz
Nevermind the post. I figured it out. You need to connect the two high beam indicator wires together and the two brake light wires which is what the jumper plug does.
Old Oct 29, 2014 | 06:42 PM
eakermeld's Avatar
eakermeld
What is drl or drls?
Old Oct 29, 2014 | 07:07 PM
Ddaybc's Avatar
Ddaybc
I think it's DRL and it usually stands for Daytime Running Lights. I think dri is a typo. My 95 Dodge had the DRL disabled by the dealership as, according to them, they failed so often it was simply cheaper and easier to bypass it instead of constantly replacing the module.
Old Oct 29, 2014 | 07:14 PM
White 97 xlt's Avatar
White 97 xlt
I could be wrong, but I took DRLS to be plural of DRL (Daytime Running Lights).. Maybe he will come back and clear it up.....
Old Oct 29, 2014 | 07:21 PM
eakermeld's Avatar
eakermeld
Thanks, guys. I couldn't figure out what high beams and brake lights had in common. You never know when you might need to know!
Old Oct 30, 2014 | 05:57 AM
dixie460's Avatar
dixie460
DRL is daytime running lights, like GM and Turd-yota have where the headlights are always on even during the day. Looks retarded to me, and what's even funnier is that it's supposed to be a safety feature, but actually ends up making the roads LESS safe since apparently when your vehicle is equipped with the drl it makes it perfectly acceptable to not run any other lighting in low visibility conditions. Not even fog. Or heavy rain.
Old Oct 30, 2014 | 08:21 AM
cbakker's Avatar
cbakker
Which 9th gen trucks had this?
Sent from my iPhone using IB AutoGroup
Old Oct 30, 2014 | 09:08 AM
Puddy's Avatar
Puddy
Old Oct 30, 2014 | 09:40 AM
Conanski's Avatar
Conanski
Yes.. I often see somebody driving around after dark with nothing but the DRL lights on.. no taillights which is a hazard but those people are in the minority. But at those hard to see times of day.. dusk and dawn and when driving into the sun daytime running lights do make approaching cars more visible so they are a good feature. DRL started appearing on these trucks around 1990 and all vehicles in Canada have them.
Old Oct 30, 2014 | 11:37 AM
abranz's Avatar
abranz
I'm referring to daytime running lights. Previous owner pulled the fuse for them but it also controls o2 sensor heater and backup lights. So once I replaced the fuse I had a malfunctioning DRL module which left the lights on with the truck off. I unplugged the module but then didn't have dash brake light or bright light indicator. Researched it and found out ford had a jumper plug which connects four wires ( 2 for bright indicator and 2 for brake light switch). I don't have the jumper so I cut and soldered the wires and everything works fine and the DRLs are gone.
Old Sep 12, 2016 | 06:23 PM
Misky6.0's Avatar
Misky6.0
in my opinion, it's not the DRL so much as the electronic dashboard. My '97 Tahoe had DRL, but without putting on the headlights in the dark, you couldn't see the dashboard to know your speed.
With digital dashboards now, you can read everything and not realize you don't have any exterior lights on at all.
Old Sep 12, 2016 | 08:37 PM
cbakker's Avatar
cbakker
Wow, old thread. Couldn't remember anything about it when I got the notification. I'd still like to know how the 9th gen trucks ran DRL's. Did they have rain sensors back then? I don't believe my truck has them, but if it did, hopefully my PCM swap doesn't screw it up.
Old Sep 13, 2016 | 10:28 AM
Phy's Avatar
Phy
I think the Canadian trucks had to have DRL.
Tomcat74
Sep 25, 2016 12:48 PM
rclark1
Feb 10, 2006 07:09 PM
4speedvan
Jan 26, 2005 05:47 PM
commandersander
1997 - 2003 F150
Mar 18, 2004 11:30 AM
