1978 - 1996 Big Bronco
needing engine specs for 351m 79 bronco
Old Jan 13, 2010 | 10:04 AM
driverreturnonfoot's Avatar
driverreturnonfoot
I redone the heads on my bronco 351m motor the problem I am running into is the torque specs on the rockerarms and the gapping of the rocker to springs can someone please help...everything on the motor is factory no upgrades if that helps
Old Jan 13, 2010 | 10:47 AM
alxsnmr's Avatar
alxsnmr
Classic Truck - Classic Truck Shop
IIRC, Haynes manuals often showed the 351M/400 using the same torque specs as the windsor blocks.
Old Jan 13, 2010 | 11:22 AM
driverreturnonfoot
they also say look at the 302 spec also that why I am confused on which to go by. I used to have a shop manuel for the truck but lost it in a fire that had the exact specs with no confusion
Old Jan 13, 2010 | 02:44 PM
alxsnmr's Avatar
alxsnmr
The classic truck link in the post has the specs listed in it for you.
I dont think it was the 302 as I recall something was different but not sure what. Though the 351W did have alot/if not all of the similar torque specs
Old Jan 13, 2010 | 03:15 PM
driverreturnonfoot
Thanks that link was helpful but still stuck on the adjustment how much gap I would need between the rocker and top off the spring
Old Jan 13, 2010 | 05:06 PM
alxsnmr's Avatar
alxsnmr
Hydraulic lifters do not require the gapping of the mechanical lifters, i.e. valve lash. So you torque the rockers to spec, unless you switched to a mechanical lifter cam from the factory standard hydraulic lifter cam...Then you would have to find the old 351C mechanical specs or the specs of the cam.
Old Jan 14, 2010 | 07:47 AM
driverreturnonfoot
Thanks again that helped me out a lot
sewelldave
Dec 19, 2014 09:55 AM
Bronco_601
Oct 5, 2013 10:22 AM
hd78bronco
Engine Swaps
Oct 15, 2010 09:43 AM
airride41
Nov 6, 2007 12:36 PM
