Revs slow?:(
Old Jan 13, 2009 | 08:41 PM
blue66tang95f150's Avatar
blue66tang95f150
Revs slow?:(
I have a 95 that seems to rev slow. It has some glow plug issues I need to correct, but I dont think that has anything do do with it reving slowly. I thought it ran fine up till my brother in-law just bought a 96 with a PSD. He let me test drive it and sitting still and just hitting the throttle his truck reved way faster than mine. I mean his would rev to 3k like nothing. While mine seems to take forever compared to his. Driving down the road they seem about the same. His has an auto and mine has a 5 speed. I actually think mine gets up and goes better than his does even with an exhaust leak before the turbo. So what do you guys think. Would o rings on the injectors cause this? I think the are worn. I think I remember reading somewhere that if your motor runs rough from 2300-2900 when you just floor it that the o rings are shot? Is that true? My truck has 180k his has 140k. Thanks for any help.
Old Jan 13, 2009 | 08:43 PM
c00nhunterjoe's Avatar
c00nhunterjoe
yours could be leaking, does it smoke and carry on or just rev slow and smooth? also the exhaust leaks pre-turbo can cause loss of power
Old Jan 13, 2009 | 08:52 PM
blue66tang95f150
No it doesnt smoke at all even when I floor it. It revs smooth till 2300 rough till 2900 then smooth again.
Old Jan 13, 2009 | 08:56 PM
c00nhunterjoe
they could be leaking, usually you get a little smoke from the tailpipe along with the rough accel. definatly need to fix the leaking up-pipes. does it still have a cat on it?
Old Jan 13, 2009 | 09:02 PM
blue66tang95f150
Its actually the drivers side exhaust manifold that is leaking, it popped a bolt head. Yeah it still has the stock cat on it I believe.
Old Jan 13, 2009 | 09:03 PM
c00nhunterjoe
remove the cat and see if it runs any better, may be getting clogged up as well, and definatly fix that exhaust leak!
Old Jan 13, 2009 | 09:06 PM
blue66tang95f150
Yeah I would like to fix he exhaust leak, but I am simply out of time for a while. Ill see if I can gut the cat though.
Old Jan 13, 2009 | 09:08 PM
c00nhunterjoe
if nothing else the gutted cat will give you a little more power. alot if its clogged up
f350hammer
General Automotive Discussion
Jul 22, 2014 05:43 AM
f350hammer
Modular V8 (4.6L, 5.4L)
Jul 21, 2014 09:35 AM
TR 1
Modular V10 (6.8l)
Aug 8, 2013 03:54 PM
savage250
23
Sep 14, 2010 10:58 AM
modru2004
Oct 4, 2004 08:48 PM
