Sponsored by: Auxito
**Update**Spark plug blown out Must Read
Old Jan 13, 2009 | 04:28 PM
lucky57's Avatar
lucky57
Thumbs up **Update**Spark plug blown out Must Read
Ok here's the whole story:
2001 F-150 2WD short bed 5.4 Triton 77,000 miles
Blew #3 spark plug out of cylinder head.......towed to Ford....They checked it and said they do not fix heads...replacement cost for new head and labor $3600.00
No I did not take that advice.....checked 6 repair shops.....Prices were for tap in threads in #3 plug, insert new insert from Timeset, change all plugs and clean up.
First shop wanted $1100.00
Second shop $413.00
Third shop $850.00
Fourth shop $950.00
Fifth shop $1300.00
Sixth shop $900.00
I went and spoke with the shop that was the lowest,
They had one mechanic that had done this 2 doxen times. They showed me the parts and assured me the work would be done right.
The work has been done, the spark plug coil needed replacement on #3 due to the blow out, and all the coil plugs.......Total $613.oo
The truck drives good................but I have seven more plugs that could still also blow out..........
I don't know what to say..............Im shocked.........this is a very bad thing........because You can not prevent it from happening???????
I like in the valley of the Sun ------Phoenix Arizona
Old Jan 13, 2009 | 05:49 PM
firefighter1416's Avatar
firefighter1416
3600$ huh what a bunch of bs for a head and labor, i would have done the same thing glad you got it fixed
Old Jan 13, 2009 | 06:09 PM
n5926g's Avatar
n5926g
Pull the remaining 7 plugs,look at the threads in the head,if they look good,put the plugs back in,torque to proper specs,and let it bump....
Old Jan 13, 2009 | 07:07 PM
galaxie641's Avatar
galaxie641
I was pretty sure Ford had at least one approved kit that they would use, of course it still costs twice as much as anyone else. Also, I should have mentioned in the other thread, you can get a set of new PI heads for around $1200 off the net.
Old Jan 13, 2009 | 09:09 PM
vze2sgxa's Avatar
vze2sgxa
Second shop $413.00
Third shop $850.00
Fourth shop $950.00
Fifth shop $1300.00
Sixth shop $900.00
Yes, you can prevent it from happening. Remove the plugs at the required interval, check or replace them as needed, then torque them to specs on a cold engine and you will be fine. It's like my old man used to always scream at me and my brother every 30k miles on his truck: "Them plugs ain't gonna change themselves."
tmehrkam
Modular V10 (6.8l)
71
Mar 19, 2025 10:22 PM
thollist
Modular V10 (6.8l)
May 17, 2024 03:28 PM
_Rick_
Jul 19, 2015 10:28 AM
SDV10
Modular V10 (6.8l)
Nov 24, 2013 08:44 AM
DrewCosgrove
Mar 5, 2006 09:32 AM
