I'm about to do the scheduled maintenance on my Exploder, and about to go to the parts store to get the stuff I need. Anyway, as someone here suggested, I'm going to get muffler bearings and new fluid for the turn signals. Is there anything else I'm missing? What do you guys change at 150k miles?
Make sure you have the appropriate air in the tires, winter air right now, drain and refill in late spring ready for the summer
Mine ('91) has 205+k on it. Truthfully I did nothing special at 150k.
I have a 94 ford explorer and when braking hear a humming and grinding noise and its not the brakes or rotors. I just replaced the wheel bearings inner and outer on both tires in front. the nosie comes from the front left side i was thinking maybe caliber or master cyclinder what u guys think??????????????
If it only does it when braking, then it's probably brake related. Check and make sure the claiper slide pins are greased. It could also be the pad wear sensor hitting the rotor or the backing plate if its messed up. Does the truck pull at all when braking?
