1950 Hood Spring Location
Old Jan 12, 2009 | 10:02 AM
dick1950's Avatar
dick1950
I'm assembling my piles of parts into a truck and I'm confused. Is the hood spring on the plate that attaches to the valance (that has the F O R D on it) stickin up. Or is it on the plate attached to the hood sticking down.
The pictures in the assembly manuals show it on the hood side (pointing downward) but I have two of the lower plates and both have the spring on them pointing up. which is correct?
Thank you
Dick
Old Jan 12, 2009 | 10:11 AM
bigwin56f100's Avatar
bigwin56f100
on the F O R D panel pointing up. I removed one two weeks ago and thats how it was on a 1950
Kevin Bigwin
Old Jan 12, 2009 | 10:59 AM
bobj49f2's Avatar
bobj49f2
The rod with the spring points up from the filler panel on a '48-50, and down from the hood on a '51-52. The latching mechanism is in the hood on the '48-50, and in the filler plate above the grill on the '51-52. That's one of the reasons you can't mix and match parts from the front clips from the different styles:
Old Jan 12, 2009 | 12:36 PM
dick1950's Avatar
dick1950
Spring
Bob,
The problem is that according to the picture you sent for 48-50 trucks, the spring attaches to the plate that attaches to the hood. However, as Kevin mentioned my spring is also on the lower panel that attaches to the F O R D valance panel.
Where is the spring on your 49 and 48 truck? Like the picture in the IPC?
Dick
Old Jan 12, 2009 | 12:42 PM
bigwin56f100
The plate in the pic is the plate that bolts to the hood and the latch pin is just shown under as this is where it goes. They are just showing how it all fits together. actually bolts to the panel with the F O R D letters
# 16848 bolts to the hood and it has the "CATCH" in it so to catch the hood closed the pin needs to go on the upper grill panel.
Kevin Bigwin
Old Jan 12, 2009 | 01:22 PM
51PanelMan's Avatar
51PanelMan
On 48-50 trucks, the spring was attached to the top of the panel with the FORD letters. On 51 and 52 trucks, a similar spring was attached to the hood.
Maybe this will help.
Here's the same part but from a 51/52 (51 pictured). Note the absence of the spring (which mounts to the hood. Missing the latch assembly that bolts over the reddish paint, but note the hole in center for the hood mounted spring and safety catch).
Here's the same part but from a 48-50. Note the spring in center. Also, see picture of hood below.
Here's the underneath of a 48-50 hood. Note that the spring goes inside the hole in the middle of the pan under the hood.
TRIVIA TIME. By the way, can anyone tell if this hood came off of a 6 cyl or a V8 truck? Let's see how well you guys know your trucks.
Old Jan 12, 2009 | 03:07 PM
bobj49f2's Avatar
bobj49f2
Ilya,
From the picture the hood is off of a V8, I'll let someone else tell why.
Old Jan 12, 2009 | 03:17 PM
51PanelMan's Avatar
51PanelMan
Originally Posted by bobj49f2
Ilya,
Are you sure about that, Bob???
Old Jan 12, 2009 | 04:40 PM
bobj49f2's Avatar
bobj49f2
Well, if you look at the passenger side it looks like an eight, but if you look at the driver's side it looks like it might be in the six position. But, it would be difficult to stretch a six shield across to meet the eight position. I think I'll stick with the eight.
Old Jan 12, 2009 | 09:12 PM
dick1950's Avatar
dick1950
Thank you very much. Nothing like pictures.
Dick
Old Jan 13, 2009 | 10:48 AM
bigwin56f100
That hood was from a "7" cylinder. Looks like the v-8 position on one side and the 6 cyl on the other so I say its from a 7 cyl
lol
Kevin Bigwin
Old Jan 13, 2009 | 10:54 AM
tip49's Avatar
tip49
8 or 6
I'm with Bob, although cocked, it fits an 8 cyl ; not 6 cyl the way it is assembled.
Tom
Old Jan 14, 2009 | 01:49 AM
51PanelMan's Avatar
51PanelMan
Even though the air guide is cocked, it's still in the 6 cyl position.
Here's where the 8 cyl attaches. Notice that the mounting location is a few inches below the 6 cyl mounting holes.
The 6 cyl air guide is a little over 31" wide, while the 8 cyl air guide is slightly over 33".
Old Jan 14, 2009 | 08:04 AM
bobj49f2's Avatar
bobj49f2
I knew that!!!
I should have taken a walk into the shop to verify it though.
Old Jan 14, 2009 | 10:01 AM
51PanelMan's Avatar
51PanelMan
I knew that!!!
Bob,
You should be stripped of all your trucks and parts for failing to answer that question correctly!
I expected the incorrect answer from a rookie, but not from you.
